Clutch Replacement
Old Jun 30, 2008 | 01:57 PM
Ryan2008's Avatar
Registered Paratrooper
Clutch Replacement
I'm new to the world of manual trannys so bear with me. I heard chirping in the tranny when at idle in neutral so i had Mazda take a look and they said the clutch was just about done. They wanted $1300 so i said **** it, ill have someone else do it(i dont have the tools to do it myself). Other places said about $300 and I could provide the clutch. I was looking at ACT stage 2. My question is, what do I need to buy if I'm upgrading to stage 2? Just the disc or...?
Thanks in advance guys.
Old Jun 30, 2008 | 02:20 PM
kersh4w's Avatar
Hit & Run Magnet
you dont have the horsepower for the stage 2, not even the stage 1. lol.
go for the stage 1. if you have the money you might look into getting a lighter flywheel in there while they are at it.
Old Jun 30, 2008 | 03:07 PM
8is>enuff's Avatar
Bland
If they didn't do a teardown to take a look at your clutch and you haven't experienced the clutch slipping I'm pretty sure they're taking you for a ride.
See if the sound goes away when you press on the clutch pedal. It could be the throwout bearing, which is commonly noisy on the 8.
Old Jun 30, 2008 | 05:13 PM
Socket7's Avatar
ಠ_ಠ
start your car with the parking brake on. put it into first and let out the clutch. If the engine stalls, your clutch is fine. If the engine keeps running you need a new clutch. If your car suddenly starts moving forward, you need brake pads and probably a new pair of underpants.
(needless to say, do this test somewhere that you won't hit anything if your car does happen to move. Like an empty parking lot.)
Old Jul 2, 2008 | 02:46 PM
prisonerofcs's Avatar
Rxhausted
I do this test at least once a week. Never on purpose. Now I have a good justification for forgetting to take the parking brake off
Old Jul 5, 2008 | 09:53 AM
yale02's Avatar
Still plays with cars
nice teat!
Old Jul 5, 2008 | 10:22 AM
thats about the same as what my dealership has quote me 2-3 months ago.
I almost got a heart attack.
I never really had the intent to let them do it, just kinda curious so I asked and ... whoa
I dont think u need a new clutch, just check it out urself.
Old Jul 5, 2008 | 10:34 AM
Ryan2008's Avatar
i think ill go test it out now haha. thanks for the help guys. And you also think a stage 2 is a waste at this point if i do need one?
Old Jul 5, 2008 | 12:23 PM
ken-x8's Avatar
start your car with the parking brake on. put it into first and let out the clutch. If the engine stalls, your clutch is fine. If the engine keeps running you need a new clutch...
If it keeps running, your clutch is *really* gone. You probably don't even need to do this test.
My preference for testing a clutch is to drive up a hill in a reasonably high gear - not lugging, but high enough that you need a decent amount of throttle. Then take a stab at the clutch. If it grabs as soon as it comes back up, fine. If it kind of whizzes before engaging, it's worn.
Ken
Old Jul 5, 2008 | 09:51 PM
04RX8man's Avatar
Rotary Powered Countryboy
I personally do the e-brake 1st gear test it seems to work but either one running in a high gear trying to pull the vehicle hard up hill will let u know also I believe(correct me if I"m wrong) running at a high rpm in a certain gear u can hear slipping/feel slipping if it's bad....
Old Jul 5, 2008 | 10:15 PM
Macius8's Avatar
I've had the chirping noise for a while now, probably more than 20k now lol, if my clutch goes then i'll replace it right away, but Im not going to worry about it now, have some other things I want to take care of. If you're looking for a good replacement look up BHRs clutch/flywheel combos, a great improvement over stock performance wise as well, and its runs $ the same as a stock setup
Old Jul 10, 2008 | 06:38 AM
Ryan2008's Avatar
From doing the e-brake test, it definitely grips hard. shuts it right off with a hard jolt. I'll try the other test when i get a chance. Thanks for the help guys. As far as performance clutch/flywheel and whatnot, what do you guys recommend? I should definitely get a clutch kit with flywheel if I'm having it replaced right? Best Brand? Etc.
Thanks in advance.
Old Jul 10, 2008 | 08:49 AM
Ryan2008's Avatar
Ryan, there are a lot of threads where we have discussed clutches and flywheels ad nauseum. SPEC and BHR teamed up to put some tweaks on the SPEC clutches and flywheels that make them a little better for the RX-8.
I figured while I had a thread, I'd ask. But I'll do a search too. Thanks.
Old Jul 10, 2008 | 09:37 AM
Ryan2008's Avatar
How much does your flywheel/clutch kit cost?
Old Jul 10, 2008 | 09:49 AM
SpIcEz's Avatar
I havent gotten a light flywheel for the RX8 yet but I concur that light flywheels for performance are one of my favorit mods.
Last one I had was on a 2001 Sentra SE, stock was about 20lbs, fidanza was 9.5lbs.
Made a WORLD of difference in feeling, rev matching and acceleration.
Drivability only took a little getting used to.
The SR20DE on that car only reved to 6500rpm. I can only imagine how much more practical a light flywheel is on a 9500rpm high reving rotary.
Old Dec 30, 2008 | 07:50 PM
itspec53's Avatar
Question
The "chirping" is the pivot where the slave cylinder plunger meets the clutch fork. All you need to do is put some high-temp grease in the pivot cup and that should take care of the problem........for a short while, anyway. This noise recurs after a while.
To add the grease or otherwise lube the pivot cup you can reach it from the driver's side of the trans from underneath the car.
kersh4w is also correct about your clutch needs/demands. Make sure to exercise due diligence before deciding what you wish to buy.
do you happen to have a picture or diagram of where i should be applying grease?
I reached up from underneath and gooped on some grease to the rod that's sticking out and to the entire general area, but the chirping sound is still there.
Same symptoms as mentioned above, chirping at idle in neutral that goes away when the clutch is slightly depressed.
i've got 37K miles on my '05, still on the stock clutch.
thanks!
Old Dec 30, 2008 | 07:53 PM
staticlag's Avatar
The Professor
thanks!
Yeah lubing that little rod is the best thing you can try without dropping the tranny & either lubing the clutch fingers or replacing the throwout bearing.
Old Dec 30, 2008 | 08:00 PM
itspec53's Avatar
THanks, I'll guess I'll be paying a visit to the dealership tomorrow.
I've had this happen on my previous car, and greasin' up the slave cylinder worked, but not on this car.
Old Dec 30, 2008 | 09:14 PM
staticlag's Avatar
The Professor
Hmm, mazda said the clutch was "just about done", well that could be another 10-20K miles depending on how you drive it.
Honestly I wouldn't replace it until the clutch was actually done.
Old Dec 31, 2008 | 01:24 PM
itspec53's Avatar
BINGO! Good call, static.
so i took it in this morning and let them hear the chirping while i was in the car. they took it into the shop, and an hour later came out and told me that they were gonna replace the pilot bearing under warranty. hopefully this fixes the problem, should be ready pretty soon.
Old Jan 3, 2009 | 10:32 PM
Delmeister's Avatar
If any bearing, it'll be the release bearing.
How can that be when he says
......chirping at idle in neutral that goes away when the clutch is slightly depressed.
Is the bearing dragging on the clutch release fingers in neutral?
Old Jan 4, 2009 | 01:53 AM
JantzenRX-8's Avatar
How many miles does a stock clutch usually last under normal driving conditions? I don't have an issues with mine but i'm just curious.
Old Jan 5, 2009 | 09:15 PM
Delmeister's Avatar
Read the first three words again, especially the first one.
The car is in neutral
Shafts in bearings, and gears, turn
The release bearing is sitting there doing nothing
There is a chirping sound
The clutch is engaged (I know he said 'slightly' but I take it the sound does not come back if he engaged it fully)
All previously turning shafts and gears stop turning
The release bearing is under load and turning
The chirping sound goes away.
I know you said 'IF' but do you mind telling me why you would even bring it up as a possible culprit?
Old Jan 5, 2009 | 10:17 PM
04RX8man's Avatar
^ true true
Old Jan 5, 2009 | 10:27 PM
My stock clutch has 85k on it with a bunch of track days and daily hard driving. Mine is just starting to show sign of wear.
