Engine Removal
Old Jun 30, 2008 | 12:26 PM
RenKat's Avatar
Engine Removal
Can the engine and trany be removed at the same time ?
If not then why ?
Old Jun 30, 2008 | 02:25 PM
kersh4w's Avatar
Hit & Run Magnet
usually they are removed one and then the other. mostly because a half dozen people arent working on the same car at once.
but if you mean can they both be out of the car at the same time, sure why not?
Old Jun 30, 2008 | 03:22 PM
expo1's Avatar
He's as bad as Can
I believe if you remove them from the bottom, both can be taken out at the same time.
Old Jun 30, 2008 | 05:57 PM
olddragger's Avatar
would not advise this through the top---olddragger
Old Jun 30, 2008 | 10:52 PM
You cant do it if you try to pull it out from the top (engine & tranny at the same time)
you can do it at the bottom.
but I mean, why dont you just take the tranny out from the bottom, then just *drag* the engine out from the top, is much easier that way (its a pain in the *** to take the engine out from the bottom cuz u gotta jack the main frame up high high)
Old Jul 1, 2008 | 12:19 AM
MazdaManiac's Avatar
If anyone was watching my live engine swap on the net a few weeks ago, you might have noticed that we actually lifted the motor and tranny out together.
I don't recommend it, but it can be done.
I put them back in separately.
Old Jul 1, 2008 | 12:37 AM
paulmasoner's Avatar
Asshole for hire
dats becuz you haz speshal powaS!!!
Old Jul 1, 2008 | 01:40 AM
ScottyStyles's Avatar
Tailhappy
Not true. I took the engine and tranny out at once through the top, in a low-ceiling, single car garage. I have pictures to prove it, too.
However, I would not, under any circumstance whatsoever, recommend this route.
Old Jul 1, 2008 | 01:58 AM
Asshole for hire
No, Paul, it's because he has special powaz.
fixored!
Shhhh! dont let the secret out, no one knows that Jeff is actually an incapable figure head for a vast team of actual mad scientists....
Old Jul 1, 2008 | 04:10 AM
I prefer to call them Evil Minions, dontcha know!
Old Jul 1, 2008 | 05:55 AM
Its gonna be a real pain in the ***
Its better to tell people that *it cant be done*
Old Jul 1, 2008 | 01:41 PM
RenKat's Avatar
What is the issue
What is the issue?
Is it a clearance problem with the ground (trany tail).
Or is it because you have to remove so many other parts (Cross member, Cat, PFF etc)
Im asking because I am going to replace the engine, trany, clutch and cat.
Old Jul 1, 2008 | 02:30 PM
The whole thing ends up dangling at a really acute angle.
You bang into the A/C compressor and lines, heater hard-lines and just about everything else.
There is absolutely NO advantage to trying to do it this way.
I tried it just 'cuz I could.
It sucked.
Having had a dozen of these things out of the car in all possible combinations, I can tell you that pulling the tranny off first (if you are going out the top) is the only way that makes sense.
Old Jul 1, 2008 | 03:39 PM
RenKat's Avatar
Thanks for the replies
It just seemed like the trany bolts are going be hard to get to.
What kind of tool arrangement did you guys use (long extensions, swivels etc)
Old Jul 1, 2008 | 03:50 PM
Nah, they are directly accessible.
Just drop the PPF and they are all pointed right at you.
Old Jul 1, 2008 | 03:54 PM
RenKat's Avatar
Thank You All
Old Jul 1, 2008 | 03:57 PM
Before you remove the PPF make sure to prop the rear differential pinion angle(assuming this is a DIY job at home in the garage) or the PPF is a BITCH to remove.
I just unbolt it from the diff, drop it and then unbolt it from the tranny.
Falls right out.
Old Jul 1, 2008 | 04:10 PM
Easy_E1's Avatar
Hmmmm,,, Evil maybe on a special occassion. Minion,, agian maybe on a special occassion with the right girl.
Old Jul 1, 2008 | 04:44 PM
While suppporting what?
I don't understand the question.
I undo the horizontal bolt and then the nuts and it drops right off the diff.
Because of the lever arm, it takes no effort at all to support the PPF from that end.
Then I just let it down to the floor and zap the other end.
Old Jul 1, 2008 | 11:38 PM
That PPF is heavy. I never expected it to be THAT heavy.
oh well, thats how it is.
Old Jul 1, 2008 | 11:57 PM
Asshole for hire
kane was just saying a couple weeks ago how he needs some minions or underlings... maybe you can spare him a few?
Old Jul 2, 2008 | 10:36 AM
olddragger's Avatar
it was a good idea for me to put a protective piece of plywood in front of the power streering as insurance. That damn a/c unit was the biggest pita of pulling it. You dont have to but because it is so easy to do i also pulled my front clip as more insurance from accidental dings and stuff.
if i can be of any help just holler out.
olddragger
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
rotorocks
47
May 11, 2016 03:23 PM
Bamaham
Jul 23, 2015 08:08 AM
ironj221
Jul 16, 2015 10:16 PM
