Change In Oil.....
Old Jun 29, 2008 | 11:22 PM
Doro Rx-8's Avatar
Change In Oil.....
Just moved to florida from south dakota. I was using 5w-20 up in the colder south dakota and now since i have moved, i haved noticed a difference in the idle. Should i change to a 5w-30 since it is much hotter and more humid?
Old Jun 30, 2008 | 12:08 AM
Old Rotor's Avatar
That would be a good start.
Mazda does recommend 5W20 but they also say use whats best for your environment so if it's HOT where you drive use a heavier grade. Here is what the manual says..........
Engine oil viscosity, or thickness, has an
effect on fuel economy and cold-weather
operation (starting and oil flow).
Low-viscosity engine oils can provide
improved fuel economy and cold-weather
performance.
But high-temperature weather conditions
require higher-viscosity engine oils for
satisfactory lubrication.
Old Jun 30, 2008 | 12:44 AM
BMonkey's Avatar
This could also be related to your ignition system. What year is your RX8? When's the last time you changed the plugs?
Old Jun 30, 2008 | 01:36 AM
hakuna matata!
5w30 is definitely where you want to be at if not a tad heavier, especially in a climate like Florida.
Old Jun 30, 2008 | 10:16 AM
Doro Rx-8's Avatar
Thanks guys, Its a 2004 with only 28,678 miles and i changed the plugs like 5k ago somewhere around there i think.
Old Jun 30, 2008 | 10:21 AM
mattrotary34's Avatar
dont hate...just rotate!!
im running 10w30 here in AL... works wonderfully
Old Jun 30, 2008 | 11:43 AM
Socket7's Avatar
ಠ_ಠ
I just made the switch to 5w-30 from 5w-20 Didn't notice any change in idle or performance by doing so. When was the last time you replaced plug wires and coils?
airlive
Jun 28, 2020 07:46 AM
mdl0209
May 23, 2019 05:46 PM
Danield97
Sep 30, 2015 05:59 PM
XianUnix
Sep 29, 2015 03:48 PM
