Q for engine breakers...
Old Jun 29, 2008 | 06:07 PM
User24's Avatar
This is a 25 mph zone. You've finished coming to a stop and are re-launching to accelerate. But the next stop sign is within visual range. Are you going to hit 2nd or 3rd gear?
2nd gear: You shift from 1st to 2nd gear after launch. Since the next stop is so close, you just stay in 2nd and ease off gas to engine break when you're close.
3rd gear: You shift to 1st, 2nd, and then 3rd after launch. Ride 3rd to stop sign, then downshift to 2nd to slow down.
Is one method or the other more conventional or more approved? I'm sometimes a bit conflicted in these 25mph zones.
Old Jun 29, 2008 | 06:10 PM
Zerotide's Avatar
Snick-Snick Gearbox
Since its a 25 mph zone I would stay in second and ride it. I dont like to use brakes when I dont have to.
Old Jun 29, 2008 | 06:15 PM
Rx8urZ's Avatar
i say just leave it in first
Old Jun 29, 2008 | 06:57 PM
kersh4w's Avatar
Hit & Run Magnet
i'd go to second, hit 25mph, put it in neutral and then coast.
Old Jun 29, 2008 | 07:23 PM
Spinning Sushi's Avatar
I <3 Sushi
Engine braking helps save gas.
When the accelerator pedal is depressed, the fuel injectors stops injecting fuel completely.
Old Jun 29, 2008 | 10:16 PM
leave it in 2nd, dont put it to N thinking that you might save gas.
you're actually using gas in N.
if u leave it in gear and take ur foot off, the ECU will shut gas delivery.
Old Jun 29, 2008 | 10:32 PM
kersh4w's Avatar
Hit & Run Magnet
i like rolling, im not too concerned about that little bit of gas.
Old Jun 29, 2008 | 11:12 PM
but some people wants to save *as much as possible*
Thats not me tho lol ! if I wanna save, I wouldnt be driving this car
Old Jun 29, 2008 | 11:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i would leave it in 2nd and coast to a stop or put in neutral and coast(done it forever and a hard habit to break but i'm trying...any little bit of savings on gas is worth it in my book)
Old Jun 30, 2008 | 02:48 AM
neXib's Avatar
Using brakes more than you have to is better than changing gears more than you have to, brake pads are cheaper than clutches
I'd probably also just use second though, I'd probably spend a lot of gas flooring it until I had to stop and brake violently :D
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
