Overheating engine?
Old Jun 29, 2008 | 04:09 PM
mikharev's Avatar
Overheating engine?
Hello,
I have a 2005 Mazda RX-8 and have the following issue: when I drive in a stop-and-go traffic my car dies on me. First I start losing power, the car won't accelerate as fast as it should, then it kind of starts vibrating and then dies. It only seems to happen when it's hot weather outside. When I pop the hood and let it cool off for a bit, it barely starts and I am able to drive (not for very long). I tried taking it to the dealership but they can't figure it out. The diagnostic shows no bad codes. I appericate any opinions. Thanks!
Old Jun 29, 2008 | 04:34 PM
ur dealership just tried to pull codes ? Tell them do the compression and Vacuum test.
And have them to check for clogged Catalyst converter too.
Old Jun 29, 2008 | 04:39 PM
mikharev's Avatar
nycgps, thank you for your reply!
I am not sure if the did the compression and vacuum tests but they did replace the catalytic converter and that didn't help
Old Jun 29, 2008 | 05:15 PM
robrecht's Avatar
Originally Posted by mikharev
Hello,
Print out this TSB and show it to them. Personally, I wouldn't be optimistic that decarbon process will solve you're problem, but they should have done this:
http://www.finishlineperformance.com...14-08-1924.pdf
Eventually, they may have to replace your engine but if they're not more on the ball take it to another dealer.
Old Jun 29, 2008 | 07:16 PM
mikharev's Avatar
Thanks guys! I'll try that...Really hope this will work!
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
cschoeps
Aug 6, 2015 12:44 PM
Bomba
Jul 22, 2015 06:46 AM
