View Full Version : Mazsport JUST INSTALLED!!!
Chi-Tom8
06-27-2008, 02:25 PM
got a couple questions... just installed my MAZSPORT turbo kit.. theres a lot of BS going around read a lot of unnecessary CRAP so im just going to ask.
Stock Internals i need to know what is a safe Boost for the turbo. and where can i get a good tune? willing to drive
Jedi54
06-27-2008, 02:27 PM
what fuel management are you using? Int-x?
nycgps
06-27-2008, 02:35 PM
Find somebody who knows how to do a Dyno Tune.
Int-X is based on Motec (I think)
If its AP, well, u should get a MAP from somebody.
maxxdamigz
06-27-2008, 02:45 PM
Where are you? As for how much boost for stock internals - that really hasn't been proven out to any degree yet. People blow up all sorts of stuff before they hit that limit right now. You should be good to run 10 psi, maybe 12 - maybe 330 whp. You could blow an engine at 6 psi with a bad tune/abuse so..... I think MM is running up to 14 psi but that's probably "you're on your own" territory for now.
Call Mazsport and if you can get in touch with Scott, he can tell you what WHP he's seeing from the kits at what levels of boost.
Red Devil
06-27-2008, 04:00 PM
Microtech, not Motec.
A-Spec is in Chicago and has been tuning rotary engines for years. Also Hahn Racecraft or Werks can probably handle the task.
mdw1000
06-30-2008, 12:21 PM
PM importshowoff84 about Performance Auto Works in Plainfield. They are working on tuning his Esmeril kit with the IntX. I think it is their first RX-8.
GrRx8MaZdA
06-30-2008, 12:54 PM
Which turbo kit did you install?Which type?And in how many days??
CraigRX8
06-30-2008, 05:17 PM
what he said, oh and pics
