Lock & Load
11-19-2003, 11:43 PM
I have emailed MoTeC Australia regarding their M800 and M880 engine management systems. This is their very interesting reply. Could some of you more technically-minded people decipher and summarise this for me so it's easier to understand.
Michael
Message from MoTeC
Michael,
Both Motec Japan and Motec USA have installed an M800 on an RX-8, the factory ECU is removed. The engine is no trouble after a few issues are addressed:
1) Trigger wheel must be changed from 36-2-2-2 to 36-2
2) The DC Generator must be replaced with a conventional 3rd generation RX-7 (FD3S) alternator unit. It drops in, using all the stock RX-8 mounting points, belt, and terminals.
3) The secondary injectors need to be wired in pairs
The ecu will require the SERVO code for the OMP function to work, and an M800 will be necessary in order to get the OMP to work as we need the extra injector drivers.
The car however, is a whole lot more complicated. Removing the factory ECU will terminate the dash cluster (speedo, odo, temps, fuel level, warning lights, status lights, etc.), electronic stability control, power steering, cruise control, A/C control, engine cooling fan control, emissions control, secondary air injection, and so on. ABS still functions.
The information I've had from the US indicates that gains are very hard to come by on stock parts. Also, the intake system seems to be very sensitive to how it is manipulated. It presents less than 100 kPa under the throttle at WOT - around 95 kPa. The (70mm) DBW throttle may be the choke point, not sure. There appears to be a trade-off in the design of the intake system that was very carefully examined and massaged to give the best end result. It goes to show that some manufacturers are putting a lot of effort into development - certainly in this case, where the engineers were given a target hp figure... Aftermarket tuning with the Motec ECU will come into its own with a modified race engine.
Cost would be retail for the M800, a wiring harness, new trigger wheel, fitting and tuning by a Motec dealer.
Regards,
Andrew Naumann
MoTeC P/L
Michael
Message from MoTeC
Michael,
Regards,
Andrew Naumann
MoTeC P/L
