mods!
Old Jun 24, 2008 | 08:47 AM
shizrx8's Avatar
Red face mods!
know any simple mods?
and what do u suggest me buying for my 8?
considering its all stock.
Old Jun 24, 2008 | 09:11 AM
Vasichko's Avatar
You could always go the route of the obvious.
Intake, midpipe, exhaust.
Ignition would help with some HP by providing better spark, and you wouldnt have to swap them out as much as the OEMs.
Cobb Tuning's Access Port will allow you to modify the fueling, timing, and many other things.
Of course you will not net the power gains that you would from going FI.
Old Jun 24, 2008 | 09:15 AM
Renesis07's Avatar
Vtak just kicked in yo!!
or he could always search.
Old Jun 24, 2008 | 10:59 AM
dozer's Avatar
on his 3rd rx8
Short Shifter!
Old Jun 24, 2008 | 11:21 AM
Socket7's Avatar
ಠ_ಠ
Kilowatt class assault stereo with 2 10" subs in 4080 boxes.
Clear corners.
Foglight mod
Corner blinker mod.
Driving classes (it's best to fix the nut behind the wheel first)
Old Jun 24, 2008 | 11:40 AM
shiz: please search, this topic has been covered hundreds of times.
Old Jun 24, 2008 | 11:43 AM
dshiznit1489's Avatar
Formerly Polak Graphics
Somebody say shiz?
edit: lulz
Old Jun 24, 2008 | 11:46 AM
mmats69's Avatar
93.5 octane
unless you go FI, no mods are going to get you any kind of gain. they will just change the sound. a lot of wasted money
Old Jun 24, 2008 | 11:50 AM
23109VC's Avatar
i am reasearching buying an RX8, and I"ve done the searches..
above post is correct - spending a lot of money on power mods will not net you much gain in power.
suspension mods will help - sway bars, springs, shocks, stuff like that will make the car handle even better, eliminate the body roll, etc.
but to make the car truly FASTER - adding an exhaust or intake isn't going to do a whole lot. having had a former turbo car - THOSE cars make major gains. add an ECU to an EVO or a BMW 335 or other turbo car and you immeidately pick up major hp...
the rx8 is not a car you will get lots of power out of. if you are NOT happy with the car in stock form for power delivery - unless you go fi you probably never will be.
sorry. i'm not saying you can't get power out of it..but you coudl spenda couple grand on an intake, exhaust, flywheel...and the car will be only a little bit faster.
the rx8 is not a speed demon. it's a "fun" great handling car. if you need SPEED you need something else.
Old Jun 24, 2008 | 11:56 AM
mmats69's Avatar
93.5 octane
^couldn't have been said better
Old Jun 24, 2008 | 12:03 PM
HCTR154's Avatar
Personally, I think the first mod a stock RX8 should have is a good set of lowering springs. If your shocks are getting tired, then upgrade them while you are at it.
Old Jun 24, 2008 | 12:05 PM
dozer's Avatar
on his 3rd rx8
just get a jet....
Old Jun 24, 2008 | 12:06 PM
rglbegl's Avatar
Baned
4X4 delete kit
AFE Short Shifter
And window tint
Old Jun 24, 2008 | 12:07 PM
TopGear8's Avatar
mkuhnracing.com
20B is pretty simple, you should do that.
Old Jun 24, 2008 | 05:15 PM
brilliantblackrx8's Avatar
DITTO!
gwailo
May 14, 2024 06:57 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
FubarI33t
Sep 28, 2015 08:45 PM
