Engine oil turning black...
Old Jun 23, 2008 | 11:45 PM
ashwins's Avatar
Is it normal for the engines oil to turn black? I am guessing its carbon deposit. Is it time to change oil? I check engine oil regularly, in the past 1 year that I owned the car, this is the first time I am noticing that the engine oil is darker?
Old Jun 24, 2008 | 12:09 AM
04RX8man's Avatar
Rotary Powered Countryboy
uh as the oil gets used it gets black in any car engine no matter what that is the dirt and from getting hot etc inside an engine change at 3000 miles like usual and keep adding when u need it
Old Jun 24, 2008 | 12:13 AM
cmr333's Avatar
SR Dubbed Rx8
im not trying to be a dick or anything but is this thread for real lol
Old Jun 24, 2008 | 12:14 AM
xsnipersgox's Avatar
One Shot One Kill
ahahahha, alrite.. engine oil in Chinese is call "black oil" ... i hope u know why now.
Old Jun 24, 2008 | 06:40 AM
Go48's Avatar
Depending on how you drain the oil, you will only be replacing about half the oil in the system. The oil coolers and oil lines hold a lot of oil, so as soon as you run the engine after an oil change, the old oil mixes with the new and it turns dark. Change your oil frequently and the color won't matter.
Old Jun 24, 2008 | 11:55 AM
mmats69's Avatar
93.5 octane
needs to be closed
Old Jun 24, 2008 | 12:15 PM
New Oil is like Lemon-Tea kind of golden-ish color. (Except for Royal Purple, they Purposely add some dye to it to make it look like Purple, but will fade out in maybe 10 miles of use)
Old oil is always dark/black, consider the heat, pressure, and dirt that its *absorbing* ...
Old Jun 24, 2008 | 12:16 PM
dozer's Avatar
on his 3rd rx8
ahahahahhahahahahhahahahahahhah LMFAO!!!!!!!.....oil change!...my bad dude, i dont mean to be rude, but this is funny
Old Jun 24, 2008 | 01:35 PM
it's normal.
change your oil every 2.5 - 3,000 miles.
Old Jun 24, 2008 | 01:58 PM
Socket7's Avatar
ಠ_ಠ
When was the last time you changed the oil in this car? A complete drain and refill + a new filter?
Old Jun 24, 2008 | 02:04 PM
leemoshuffle's Avatar
oil q
Don't pick on this guy people.
To answer your question;
It is prefectly fine for the oil do get very dark.
like the guy said, it will change color because of
the temp, carbon, etc.
Just be sure to change it reguarly.
I usually pour 0.50 quart of oil just to drain excess carbon.
what kind of oil are you using?
leemoshuffle
Old Jun 24, 2008 | 02:12 PM
hakuna matata!
Change your oil.. just in case no one has mentioned it yet and it's not obvious..
Old Jun 24, 2008 | 02:20 PM
XAreXAteX's Avatar
wow..rip a guy for asking a question...Your sooooo cool i wish i could be just like you.
Old Jun 24, 2008 | 03:19 PM
laythor's Avatar
I zoom therefore I am.
as has been said:
check oil level often
change oil often
drive it like it's stolen
If you really want the "clean oil" look... change the oil, drive it a day, change again.
Old Jun 24, 2008 | 03:54 PM
ShinkaTeen's Avatar
space reserved for shirt
this thread made me lose hope for humanity.
j/k.
no im not.
but dont be offended.
Old Jun 24, 2008 | 04:10 PM
crafted_soul's Avatar
Sorry to be a party pooper...but my engine oil never turns black......is it normal?
hahaha
Old Jun 24, 2008 | 04:13 PM
paulmasoner's Avatar
Asshole for hire
this might just be the most unbelievable post EVER on an automotive forum...
Old Jun 24, 2008 | 05:13 PM
Astral's Avatar
Purveyor of fine bass
Yup, it's normal, and here's something many probably don't know. Engine oil loses its color really quickly (within like 1000 miles), so color alone is not at all a good indicator of the wear.
http://www.motor-oil-engineers.com/oilcolor.htm: "In general, the color of an oil does not have any bearing on its lubrication ability or whether or not the oil is suitable for continued use."
http://www.carbibles.com/engineoil_bible.html: "And don't worry about the engine oil turning black. It will lose it's golden-brown colour within a few hundred miles of being put in to the engine. That doesn't mean it's not working. Quite the contrary - it means it is working well. It changes colour as it traps oxidised oil, clots and the flakes of metal that pop off heavily loaded engine parts. Just don't leave it too long between oil changes."
http://www.washingtonpost.com/wp-dyn...801210_pf.html: "Do not be alarmed when motor oil turns black, which can happen long before the oil's protection value is used up. Engine combustion produces soot, and other byproducts disperse throughout the oil, turning it dark."
http://www.usasyntheticoil.com/oil-c...ubrication.htm: "The color the AMSOIL on your dipstick (or any oil for that matter) has absolutely no bearing on whether or not the oil is suitable for continued use or if it should be drained and replaced."
From my experience, synthetic oils stay "golden" for a longer period of time, but I don't think I've ever drained golden-colored fluid from my last car when using synthetics. Haven't used synthetics on the RX-8 and I don't do the oil changes myself anymore, so can't relate any experiences there.
Old Jun 24, 2008 | 10:34 PM
This is funny all they tech in scholl nowadays is how to use a cell phone........
Got to learn sometime.
Start reading the stickies in the tech section.
Old Jun 24, 2008 | 11:03 PM
cmr333's Avatar
SR Dubbed Rx8
wow this is still going lol
Old Jun 25, 2008 | 09:34 AM
puch96's Avatar
....there seems to be a passion talking about oil in this forum..... not matter what the topic is.....
Old Jun 25, 2008 | 08:24 PM
User24's Avatar
Serious, who likes to come home after a hard day's work, only to find a bunch of nonsense going on at rx8clubz that needs to be put under control?
Old Jun 25, 2008 | 08:44 PM
StealthTL's Avatar
Metatron
Cool
I look forward to it.........
S
Old Jun 26, 2008 | 05:33 AM
DOMINION's Avatar
I don't buy Kool-Aid
Eeewwweee Rotary douche!
Old Jun 26, 2008 | 05:44 AM
WooHoo's Avatar
OK, OK, It's hers!
Does 5W20 turn black faster than 5W30? Will premixing keep the oil color less black over time? (Heh,Heh )
