pioneer avh-p4000dvd question
Old Jun 23, 2008 | 04:15 AM
Rx8-13b's Avatar
just wondering, i have a 4 way amp for my speakers in the car and a mono amp for 2 subs, going to install the p4000, it said it has sub out. but after a review i read that said " The only con is I wish it had a separate line out for subwoofer. As this unit has rear output that you can use for rear full range speakers or subwoofer but not both " does that mean its not guna work with my amps? or am i just stupid, somebody help??
Old Jun 23, 2008 | 08:55 AM
firebirdude's Avatar
User and Abuser
There is no dedicated subwoofer preout. You'll either have to use high-level (speaker lead) inputs on one of the amps or use RCA y-cables.
Old Jun 23, 2008 | 12:38 PM
forbidden's Avatar
If your amp has pass through rca outputs, you use those to run multiple amps. If you do not, the simple route is the rca y- cable. The better route is to purchase a Audio Control 6XS that takes one input and gives 3 outputs (inc. sub level control). It also adds a damn fine crossover, master level controller and a 6 channel line driver. This will bring the system to life.
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
