Mixing Oil weights
Old Jun 22, 2008 | 02:02 PM
Zerotide's Avatar
Snick-Snick Gearbox
Mixing Oil weights
I couldn't find anything on this on the forum so I thought I'd try to get some answers from the knowledgeable people here.
I have a problem,
I bought my RX-8 a week ago from a private party and the guy couldn't remember what type of oil he put in it. The only thing he could tell me was that he never used synthetic. So I have some Castrol GTX 5W-30 dino and my oil is ready for a top off. Let's just say for all intents and purposes he put 5W-20 in the car previously. Would it be bad to add a quart or so of 5W-30? I really have no idea what kind of oil is in there now.
Old Jun 22, 2008 | 02:05 PM
invasion08's Avatar
No its not bad.
StealthTL's Avatar
Metatron
5W30 is fine.
....and your signature picture is way oversized, the limit is 20k.
S
Old Jun 22, 2008 | 02:09 PM
mmats69's Avatar
93.5 octane
if you are that concerned, change the oil.
Old Jun 22, 2008 | 02:26 PM
Don't mix synthetic and dino.
your of to mix dino
Old Jun 22, 2008 | 02:46 PM
robrecht's Avatar
Does he even remember the last time he changed his oil. If he doesn't know what kind of oil, maybe he's forgotten because it was so long ago, or maybe he just doesn't care enough about oil to remember to change it.
Old Jun 22, 2008 | 02:59 PM
Zerotide's Avatar
Snick-Snick Gearbox
He did care about the oil he had all the oil changes and service done at a local Mazda dealer... with reciepts to prove it. Maybe it will say on those. The sticker on the window says it isn't due for an oil change for another 1,000+ miles
Old Jun 22, 2008 | 03:03 PM
ken-x8's Avatar
Let's just say for all intensive purposes he put 5W-20 in the car previously. Would it be bad to add a quart or so of 5W-30? I really have no idea what kind of oil is in there now.
No problem. For the most part you can mix brands and weights of oil. If you mix weights, you get something in between the two. When you change the oil in an RX-8, you usually only get about 2/3 of it out. So even if you do a full change you're still mixing with what was in there. FWIW, even believers in 5w20 generally see no problem with using 5w30.
I agree with Robrecht that if the guy does not remember what kind of oil he used he may not even remember when he changed it last. I recommend getting it changed and embarking on a regular schedule.
Search/browse the forum for the definitive answer on the one kind of oil that should be used.
Ken
Old Jun 22, 2008 | 04:52 PM
Revvittupp's Avatar
I have a problem,
I bought my RX-8 a week ago from a private party and the guy couldn't remember what type of oil he put in it. The only thing he could tell me was that he never used synthetic. So I have some Castrol GTX 5W-30 dino and my oil is ready for a top off. Let's just say for all intensive purposes he put 5W-20 in the car previously. Would it be bad to add a quart or so of 5W-30? I really have no idea what kind of oil is in there now.
I don't know the answer to your question, but I know that you were trying to say "For all intents and purposes"....
Old Jun 22, 2008 | 05:00 PM
robrecht's Avatar
That's very good to know when buying a used car. Would be even better to know that he topped it off every 1,000 miles or so but if he didn't drive the crap out of the car, not to worry too much. (If you live in the US, chances are very good the Mazda dealer used 5w-20 nonsynthetic.)
Old Jun 22, 2008 | 05:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
same thing happened to me when i got mine...ust changed it when it got down on the stick figured it can't hurt!!!
Old Jun 22, 2008 | 09:25 PM
DOMINION's Avatar
I don't buy Kool-Aid
I have a problem,
The Fix,
Let you Car sit for the night. In the morning change the Oil and flush it with 2 extra qts. Then fill it up. Dont over fill and your good
-Gil
Old Jun 22, 2008 | 11:10 PM
mixing weight/oil doesnt matter.
Its like mixing colors, if you mix yellow and blue, you will get green. if u put more yellow than blue, u will get light green.
if u put more 5w30 than 5w20, u might get something like 5w28 in the end.
so no biggie.
but like the others have said, if the previous owner doesnt even remember what oil it had, then I suggest you to do a change right away.
Old Jun 23, 2008 | 02:24 AM
DOMINION's Avatar
And use Castro its da bests lol
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
