Warning Light....BRAKE WARNING LIGHT
Old Jun 20, 2008 | 05:55 PM
italyhot21's Avatar
Hey Guys....
I have a 6sp rx8
My brake warning light stay on even when i have my E-brake is down......
Brake fluid is on MAX....
How do i fix that??
Can some one please help me????
Old Jun 20, 2008 | 06:31 PM
sshsbball5's Avatar
The same thing happened to me, you need to get your brake pads changed. Eventually they will rub and grind and make a horrible noise every time you use your breaks. You should get them changed before all that happens
Old Jun 20, 2008 | 06:48 PM
italyhot21's Avatar
I just got em changed like 3 days b4 that hole thing start happening....
Idk what 2 do.....
Old Jun 20, 2008 | 08:50 PM
fahrfegneugen's Avatar
there is a seperate abs light and a parking brake light I think. Is it the parking brake light?
Old Jun 20, 2008 | 10:04 PM
italyhot21's Avatar
Yeah it is the parking brake light..... its on all the time...
Old Jun 20, 2008 | 10:15 PM
Renesis07's Avatar
Vtak just kicked in yo!!
dealer? Is your car under powertrain?
Old Jun 21, 2008 | 02:03 AM
sshsbball5's Avatar
well when my brake pads were bad, it was the E-brake light staying on, not the ABS. But if you just changed your brake pads, i dont know what to tell you
Old Jun 21, 2008 | 06:04 AM
Go48's Avatar
Check your brake fluid level. Check your brake fluid level. Check your brake fluid level. Oh, and BTW, check your brake fluid level.
Like it's in the owners manual:
Parking brake warning
The light comes on when the parking brake is applied with the ignition switch in the START or ON position. It goes off when the parking brake is fully released.
Low brake fluid level warning/Electronic brake force distribution system warning
If the light stays on after the parking brake is fully released, you may have a brake problem.
Drive to the side of the road and park off the right-of-way.
You may notice that the pedal is harder to push or that it may go closer to the floor. In either case, it will take longer to stop the vehicle.
1. With the engine stopped, check the brake fluid level immediately and add fluid as required (page 8-14).
2. After adding fluid, check the light again.
Old Jun 21, 2008 | 12:01 PM
EDZRIDE's Avatar
2005 White GT
Idk what 2 do.....
Take it back to the shop that did the work.
Old Jun 21, 2008 | 12:29 PM
Maybe they bled the brakes wrong, or they just need bled. It is general maintenance every 30k anyways. Also check for leaks maybe.
Old Jun 30, 2008 | 10:24 AM
italyhot21's Avatar
Thanks Guys....
problem was solved
I just had to bled all 4 wheels and the master cylinder....
Thanks Everyone.....
Old Apr 16, 2014 | 05:04 PM
weighed's Avatar
Hey Guys....
I have a 6sp rx8
How do i fix that??
That brake fluid level thing is very tricky with the RX8. If mine's in the min and max, but low, it will still come on, and if I over fill it, it will come on. I have to keep it RIGHT below the max line or it starts coming on.
Old Apr 16, 2014 | 05:05 PM
RIWWP's Avatar
^ the problem was solved 6 years ago.
Old Mar 29, 2018 | 10:52 AM
icemantbi's Avatar
I had this issue start on me and what the problem was was that the float that was inside the brake fluid was stuck and they just had to unstick. Problem solved.
Old Apr 3, 2018 | 05:58 AM
cgilbert37's Avatar
^^^ I've had it caused by both- the break fluid float and brake pads.
cliffkemp
Dec 24, 2024 10:48 AM
xAgyex
Sep 28, 2015 08:54 AM
drlubell
Sep 26, 2015 11:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
