Trunk rusting from spoiler install?
Old Jun 20, 2008 | 05:41 PM
dying_here's Avatar
so I took a mazdaspeed replica spoiler to a shop today to get a quote for install, and he advised me not to install it I'm going to drive the car for years to come ( >3-5yrs), because eventually the drill hole be start rusting from side the trunk and eventually causes crap like water leakage?
is it true?? or thats just from poor workmanship?
Old Jun 20, 2008 | 06:07 PM
05rex8's Avatar
sold the 8... :(
poor workmanship...go to a different body shop.....factory spoilers never pose a problem that I've seen, so why would an aftermarket one if it's installed right?
Old Jun 20, 2008 | 06:37 PM
dying_here's Avatar
so someone told me i might be able to use betalink to hold the spoiler inplace instead of drilling holes, anyone has any experience if it will work? ?
Old Jun 24, 2008 | 11:45 AM
Roxie79's Avatar
My Fuzzy Mechanic
If the spoiler is installed properly there should be no problem. Once the holes for the spoiler are drilled out, it's advisable to dab on some rustoleum or primer (with a q-tip) to protect the bare metal surface, just as the paint does to the steel of the car. Depending on the wing/spoiler used, a gasket is then placed between the spoiler and car metal which helps keep water out from even entering the drill holes.
One other thing to look out for if adding an spoiler aftermarket - the weight of it. The trunk lifts should be able to be adjusted for the additional weight of the wing if needed. Otherwise, if there is not enough support from the lifts (actuators), the trunk will slam closed if not eased closed by hand.
Old Jun 24, 2008 | 01:36 PM
proper installation is the key. My MS spoiler has been on for 2.5 years and no problems at all. Proper installation is the key
Old Jun 25, 2008 | 12:39 PM
the4v3ry's Avatar
2004 Silver RX-8 Sport MT
Would you guys recommend a home install at all, or only at a shop?
Old Jun 25, 2008 | 12:46 PM
depends on how mechanically inclined you are. I just paid a shop to do it to be on the safe side
Old Jun 25, 2008 | 09:36 PM
Also a silicaone gasket is needed.
Old Jun 25, 2008 | 11:54 PM
Minotavr's Avatar
Less Fast, More Furious
How much did you pay for it ?
Old Jun 26, 2008 | 07:33 PM
XRX8X's Avatar
more then a Mazda
i did mine three years ago with a x-men wing(some like it some don't)but the key to instalinf yourself is measure three times and test fit often and be sure you get some touch up paint to out around the holes to keep it from rusting.i took mine off last week to check the sealing and what not only to find it never leaked and never rusted at all.since then i put it back on and love it still!!
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
nowakm99
Oct 9, 2015 07:10 AM
yapakanichi
Sep 17, 2015 04:23 AM
mitchrx8
Sep 13, 2015 08:05 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
