Any good reason not to go with cheap HID bulbs?
Old Jun 19, 2008 | 08:03 PM
elysium19's Avatar
I know basically nothing about different companies that make HID bulbs, except that I've heard of a few prominent companies like PIAA and such. I'd like to buy a set of 6000k-6500k bulbs to replace my OEM HID bulbs (which I understand are 4300K)
Ebay and some other website turned up a bunch of them that are like $35-$40 shipped.....which sounds almost too good/cheap to be true.
For example
Can I expect any problems if I go for these over ones that easily retail for twice that price? Is it possible they will be not as bright? Blow out?
Any advice would be helpful....thanks.
Old Jun 20, 2008 | 01:32 AM
nuke0907's Avatar
Never Blend In
i bought some 8000K bulbs off ebay for about $65. they've worked fine so far. just check the feedback on the seller and you should be fine. and be sure not to touch the glass part of the bulbs.
Old Jun 20, 2008 | 06:16 PM
Aipex8's Avatar
X e p i A
Cheap HID bulbs will probably burn out at about the same rate as halogen bulbs, so if you're only paying $30 that's not too bad. If you do spend more and get a Philips OEM quality bulb, it will last many years, perhaps the life of the vehicle.
Old Jun 20, 2008 | 07:23 PM
paulmasoner's Avatar
Asshole for hire
only reason is you get what you pay for. if you dont mind replacing cheaper bulbs more often then no issues
like he said^^^ Phillips bulbs are the best out there afaik
Old Jun 21, 2008 | 12:21 AM
laythor's Avatar
I zoom therefore I am.
price of bulb usually equates to lifespan. Cheaper bulbs can also be off color and not match perfectly.
Old Aug 5, 2008 | 01:34 PM
lancer's Avatar
dont buy cheap bulbs. I bought many of those and the quality are suck. I guess you get get what you pay
drebbrnator
Dec 27, 2018 07:02 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
Kahl
Aug 20, 2015 11:49 PM
Stubbs
Jul 28, 2015 09:23 PM
reverse01134
Jul 16, 2015 10:27 PM
