any idea what the CEL code means?
Old Jun 19, 2008 | 06:40 PM
turok4n64's Avatar
I Am Turok!!
got it checked at AutoZone (which many will say it was probably a mistake, but whatever)
the CEL is throwing this code
"Crankshaft position sensor a CKT range"
wth does this mean?
Old Jun 19, 2008 | 07:27 PM
superglue's Avatar
n00b post whore
Someone installed a crank shaft in your car when you weren't looking?
I don"t know?
Old Jun 19, 2008 | 09:48 PM
The RX-8's Avatar
FAIL.
haha
Old Jun 20, 2008 | 12:00 AM
Jon316G's Avatar
Grasshopper
wth does this mean?
Have you done any modifications... specifically any pulley upgrades?
Old Jun 20, 2008 | 01:14 AM
Eccentric shaft sensor had a cow....reset it and it probably won't come back. Mine did it a few times when I stalled the car after a spin at the track
Old Oct 26, 2008 | 05:05 PM
S1lveRx8's Avatar
9K RPM's = ♥♥
How do you reset it? I also recently got this CEL after a spin + stallout.
Old Oct 26, 2008 | 05:09 PM
Disconnect battery to reset ECU
Turn on key...pump brake pedal until the oil pressure gauge sweeps..takes 20+ pumps in rapid succession that resets the ESS
Old Oct 26, 2008 | 05:11 PM
S1lveRx8's Avatar
9K RPM's = ♥♥
Ignition on or off? When I turned the car on a second ago the CEL was gone? I have not done anything but drive up to autozone to get the diagnosis....??
Old Oct 26, 2008 | 05:37 PM
remove neg battery cable....push brake pedal 3-4 times...reconnect battery cable
Turn on ignition......pump brake pedal 20+ times until the oil pressure gauge sweeps..turn off key....and start the engine.
Your DSC light will be on...turn wheel left all the way and then right to reset and then restart car...all the lights should be out..and good to go
Often CELs will reset themselves if they aren't hard codes...The scanner will show them as pending....
Old Oct 26, 2008 | 06:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah remove battery cable to clear CEL and reset computer
WranglerFan
Aug 21, 2022 01:29 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
