in dash two din question?
Old Jun 19, 2008 | 03:04 AM
Rx8-13b's Avatar
just wondering, would it be possible to tkae out the stock dash piece, bondo all the holes that u dont need including the center part, then cut a hole to fit a two din dvd player in?
Old Jun 19, 2008 | 03:09 AM
Spinning Sushi's Avatar
I <3 Sushi
You will lose full functionality with your HVAC system.
Old Jun 19, 2008 | 03:10 AM
Rx8-13b's Avatar
wats the hvac system?
I <3 Sushi
Climate control stuff. (AC, Heat, etc.)
Rx8-13b's Avatar
do u mean the air conditioning controls? i was thinking if i left those holes, but just bondo all the buttons related to the cd player
Old Jun 19, 2008 | 03:11 AM
I <3 Sushi
It'll be alot easier for you if you buy this: http://corksport.com/store/item/2jpb...e_Control.html
Old Jun 19, 2008 | 03:12 AM
Rx8-13b's Avatar
do u mean the air conditioning controls? i was thinking if i left those holes, but just bondo all the buttons related to the cd player?
I <3 Sushi
The OEM CD Player actually controls ambient temperature and stuff. If you remove it for a double din then the displays won't work.
Rx8-13b's Avatar
but was thinking cuz my uncle works at a bodyshop and he can do the bondo stuff for me, so if thats possible, i mite as well use my stock dash piece instead of spending 500 bux on a kit
Old Jun 19, 2008 | 03:13 AM
Rx8-13b's Avatar
o, then how does the kit make u able to use the climate control? isn't is the same, except that the dash piece is premade?
Old Jun 19, 2008 | 03:14 AM
I <3 Sushi
The climate control will still work, it's just that you lose some functionality out of it. The red display will not work.
Corksport makes a kit along with a harness that will retain the LCD's functionality.
Old Jun 19, 2008 | 03:16 AM
Rx8-13b's Avatar
oo, wow, hmm, so all i wont have anymore is the time, track, and outside temperature pretty much, but the ac, fan and stuff ***** will still work?
Old Jun 19, 2008 | 03:36 AM
Rx8-13b's Avatar
hmm after a little reading, seems as though doing this would only affect my red display, but some kits say it will make my ac and heater not work, or does it just affect my display up top in the red? im confused o.O
Old Jun 19, 2008 | 04:22 AM
boanjangnararmine's Avatar
Toyo Kogyo => Mazda
From: Los Angeles - Arcadia - Monterey Park - La Jolla
with the corksport dash kit, your lcd still works. the clock and audio information does not work, however. The ambient temp will still display.
Old Jun 19, 2008 | 01:12 PM
Juice's Avatar
I made some poos
You will lose all HVAC (Heating, Ventilation, Air Conditioning) Controls. The factory radio has a module in it that these buttons and ***** use. Remove the radio and it doesn't matter if the ***** are still there, they won't work without the radio and that module. And no, ou can't take just the module out of the factory radio as it is hard wired.
The Corksport and soon enough Metra kits will come with a new module that will keep the HVAC controls working. That is why it cost 500 dollars for the Corksport kit. If it was a simple as getting a new face plate then everyone would have had a kit out by now.
Old Jun 19, 2008 | 02:06 PM
canaryrx8's Avatar
just wait for the metra as I've already mentioned a million times lol, it will do everything you want for less than the corksport and without the gaps on the sides as well. You can fab your own dashpiece sure, but to keep everything working you'll have to keep the oem radio hooked up and relocated somewhere else in the car which is a HEEYUGE pain in the ****. (just ask me, this is the way we did mine) The metra kit should be out in 2-3 months roughly, that'll give you plenty of time to shop for a sweet *** radio to put in it
LB2739
Jul 9, 2019 02:25 AM
05rx8mazda
Nov 28, 2015 09:42 AM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
yankeepicker
Sep 11, 2015 05:42 PM
