cobb/exhaust
Old Jun 18, 2008 | 10:09 AM
VS8's Avatar
VS8
4 Cylinder Rotary
Talking cobb/exhaust
so far
i have my pulleys strut bar and intake
and i am debating on what to put on next
cobb ap
or
some sort of exhaust (to be named later)
if i am right cobb will give more HP right?
but the exhaust sounds so good
Old Jun 18, 2008 | 10:53 AM
white311's Avatar
9K Smokin!
You are right......exhaust is little to no horses. The Cobb can give you more options in the future as you add components. If you go the Cobb route make sure you buy it from MazdaManiac. He will hook you up with a ton of maps to play with.
Old Jun 18, 2008 | 12:10 PM
heyarnold69's Avatar
Rotary wanabee
actually.... i would say get the cobb ap and a high flow cat .. both add hp
the high flow cat drops around 30 lbs off the car as well as a nice hp increase... only a few.... but dam the flow is soooooooo much better.
dont drop the cat on your foot.... it hurts.
Old Jun 18, 2008 | 12:11 PM
VS8's Avatar
VS8
4 Cylinder Rotary
were should i get high flo...???
sr motorsports seems expensive
does cobb work with aem intake
Old Jun 18, 2008 | 01:58 PM
white311's Avatar
9K Smokin!
cobb works with any setup......use just keep adjusting the maps until you get a low AFR percentage.
VS8 is right the cat restricting a majority of the exhaust flow. if you dont have emissions testing get a resonated midepipe.
Look on the forum and search to find reviews.
Old Jun 18, 2008 | 05:56 PM
Optical TDI's Avatar
The high flow cat doesn't remove around 30 lbs. I weighed the stock cat pipe and a non-res, non-cat midpipe and the difference was only around 7 lbs.
Old Jun 19, 2008 | 04:09 PM
NYC Drift King's Avatar
Supercharged by Pettit
How does the cobb add hp?????????????????
Old Jun 19, 2008 | 05:40 PM
09Factor's Avatar
Original Turbo 'd Auto !!
The Cobb it's self will ad weight. But the maps that reside on it change the PCM tune hence add or subtract Hp/Tq.
Old Jun 22, 2008 | 07:13 PM
JOLIET WANKEL's Avatar
Xboxgametag:Chafed Banana
from what i understand, it can change the air/fuel ratio. an engine that's running to rich, like ours come from the factory, doesn't make as much power as a leaner-running engine. a leaner tune is harder on a cat if ya run one. thats supposedly why mazda and probably other manufacturers set the engine to run rich.
Old Jun 22, 2008 | 07:18 PM
LEAN IS MEAN! i wanna get me a cobb a/p. i've read it disable the 148mph-governed speed limit. if our cars go 60mph in 6th gear at 3K, then imagine 9K in 6th gear! simple mathematics tells me 180mph! we don't have enough power to do that with the only mod being the cobb a/p of course and i'd never attempt that on the street, but anyone have any idea how much power it would take to completely wind out top gear?
Old Jun 22, 2008 | 07:30 PM
wow,
you need to start reading about areo drag..
that is the limit in the usa..
and lean also can blow a motor.. you need to read more.
Old Jun 22, 2008 | 07:34 PM
mysql's Avatar
Doppelgänger
you'd have to factor the drag coefficient.
2004 - 2008 rx-8 is 0.31
2009 rx8 is 0.30
Old Jun 22, 2008 | 07:44 PM
mysql's Avatar
Doppelgänger
stock rx8 calculates to about this..
173 whp, 124 torque.
max speed is 142 mph.
0-60 in about 5.8 sec at best
Attached Thumbnails cobb/exhaust-dyno.gif   cobb/exhaust-speed.gif
Old Jun 22, 2008 | 07:48 PM
mysql's Avatar
Doppelgänger
my car with approx 300 whp, 245 torque has a max speed of 168 mph.
That puts the 0-60 at best in 3.1 sec.
Attached Thumbnails cobb/exhaust-speed.gif
Old Jun 22, 2008 | 07:59 PM
mysql's Avatar
Doppelgänger
Comparison... keep in mind this is only a valid comparison for the MM/BHR turbo vs stock because of the torque curves... each turbo kit has it's own torque curves and that will be reflected on acceleration speed. This is also in theory stuff, since as we all know, 0-60 time on a stock rx-8 is usually more in the 6 sec range than 5.8
Attached Thumbnails cobb/exhaust-comparison.gif
Old Jun 22, 2008 | 09:58 PM
TopGear8's Avatar
mkuhnracing.com
^So how fast would you really say that you get to 60? and quarter mile?
Old Jun 22, 2008 | 11:06 PM
Originally Posted by swoope
wow,
YO, not overly lean, just lean-er. and can't aero drag be fought with more hp? i think it can. and do you have to be so condescending when you post like you're talking to a retarded toothless hillbilly? i'm just an rx-8 lover like the rest of you all.
Old Jun 22, 2008 | 11:42 PM
yes,
i have 146 mph. WAAS GPS.
the front gets really light.. and your point is?
Old Jun 23, 2008 | 12:07 AM
hakuna matata!
it's all in the tune..
Old Jan 23, 2009 | 03:14 AM
AJ's Shinka's Avatar
Enthusiast
I have to gone 145 NA. I'm just saying, and was very scary and won't evar evar do it again.
Old Jan 23, 2009 | 11:10 AM
04RX8man's Avatar
Rotary Powered Countryboy
I have a feeling this thread may get interesting..i'm all tuned in for the fight!
Old Jan 26, 2009 | 10:29 PM
4motionTT's Avatar
125 in the rx8 at the test track....
felt very stable and planted to the ground....
my audi TT did 135 in the same amount of time though and topped out at 155//
as for the mod of choice???
Cobb gets my vote, these cars run ridiculous rich, and there is more power to be found there than a slightly better flowing pipe....
and if you are going for exhaust get a single canister, it flows better than most of those 1-to-2 canisters that most companies use
Old Jan 27, 2009 | 12:18 AM
your point?
Old Jan 27, 2009 | 11:39 AM
4motionTT's Avatar
Originally Posted by Ross_Dawg
your point?
Yours???
I was having a flashback as to why did I trade my Audi for this rx8
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
