Grifter11
06-18-2008, 03:15 AM
Does the new Renesis rotary engine eat spark-plugs like the rotary from the RX-3 my dad had when he was younger ?
View Full Version : Sparkplug question Grifter11 06-18-2008, 03:15 AM Does the new Renesis rotary engine eat spark-plugs like the rotary from the RX-3 my dad had when he was younger ? Greenblurr93 06-18-2008, 09:12 AM define 'eat spark plugs'.... like the game 'hungry hungry rotors?' mysql 06-18-2008, 09:22 AM generally speaking, changing it every 30k - 60k is about normal. I was changing mine out once a year, but I used the rx7 spark plugs and they only cost $6.50 each. Greenblurr93 06-18-2008, 09:37 AM could you please elaborate on the 'rx7' spark plugs? is there a specific year to get? turbo or non turbo? any difference in these over the rx8 plug? if they are the same and provide the same result as the rx8 plug, im going to stop buying $20 plugs... SilverStreak 06-18-2008, 10:29 AM The RX8 plugs are Iridium plugs ($20 each) and are supposed to be changed out about every 30K miles by the manual. Some folks here have switched to the "standard" type of plugs rather than the Iridiums (like Platinum tips, etc.) at ($6-$7 each). The tradeoff seems to be needing to change the plugs more often (every 10-15 K miles). Search on plugs and you should find what people have been using. alz0rz 06-18-2008, 11:29 AM does the renesis "eat oil"? whenson417 06-18-2008, 03:26 PM I just bought a spark plug cleaner from Northern Tool and Equipment for about $25.00. I am able to clean all the crud build up on the plugs to make them last a hell of a lot longer than normal. I do not think I will have to purchase new plugs for a long time since I have kept all the old ones. I now have about 12 spark plugs I can swap in and out as needed. Greenblurr93 06-19-2008, 07:24 AM watch out for the cleaners... as our plugs are both platnum and iridium coated.. if the coating comes off, then plug wont function corectly ken-x8 06-19-2008, 10:28 AM does the renesis "eat oil"? No. It eats gasoline. It sips oil, kind of as a seasoning. Ken |
