Is the greddy turbo kit worth it?
Old Jun 17, 2008 | 10:50 PM
RXgrayspeed1's Avatar
i am really thinking about getting the greddy turbo kit for my car, and i can c it runs about $3200 for the kit and i was wondering if its really worth it. It only has like 6psi, is there ways to get it more with not to heavy of modding. If so like what, im kinda new with all this turbo stiff, i want to go faster.
Old Jun 17, 2008 | 10:53 PM
Falken's Avatar
Drop it into 3rd
MM Greddy upgrade. You'll spend 5k but its one of the best turbos out there.
Old Jun 17, 2008 | 11:02 PM
WingleBeast's Avatar
HAVOC
$3510.00 is the magic number. if you can get the greddy kit for less than that then do it.
if not, just get the MM/BHR kit that is basically the greddy kit with the MM upgrade and the accessport as the management.
but like i said, if its below the majic number you can get the kit and upgrade it for cheeper
Old Jun 17, 2008 | 11:04 PM
i have no cats on my car i hurd it might effect the turbo any way of doing someithng about it?
Old Jun 18, 2008 | 01:56 AM
legendkurado's Avatar
Read what I wrote on your OTHER thread about the same topic
Old Jun 18, 2008 | 02:34 AM
Fanman's Avatar
The Greddy kit by itself is just not worth it at any price. The MM/BHR upgrade/complete kit is just so much of a better solution. It fixes the shortcomings of the standard kit. I really have to ask, if you are cutting corners on a turbo kit, then you might as well start saving for a new engine. Better to spend some more money up front, than a lot more money on the back end.
Old Jun 18, 2008 | 03:20 AM
maxxdamigz's Avatar
Baro Rex
You should talk to the guy with the unlimited budget and see if he wants to hook you up!
Old Jun 18, 2008 | 09:51 AM
ChattyRX8's Avatar
Now turbo!
There are people here boosting higher than 6PSI with the GReddy. Just use a boost controller.
Old Jun 22, 2008 | 07:00 PM
JOLIET WANKEL's Avatar
Xboxgametag:Chafed Banana
isn't the greddy kit more than 6 psi? i though it was a little more than that.....like 9? still, i hear it adds over 80 whp.
Old Jun 22, 2008 | 07:17 PM
mysql's Avatar
Doppelgänger
it's made for 6 psi and it will do that to redline.
you can increase the boost, and that will give you gains, but at around 7200 rpm, the engine demands more air and the psi will drop back down to 6.
the greddy also generates more heat than if you had a higher flow turbo like MM's.
the biggest drawback to the stock greddy kit is the turbo itself. journal bearings on the turbo seems to give out and die after 12k miles or so, with or without an oil restrictor.
Old Jun 22, 2008 | 08:57 PM
Fanman's Avatar
My kit had a faulty wastegate spring that would not let me boost over 6.5 psi, and fyi, my turbo who went from 185 whp to almost 250 whp, not 80+.
JimmyBlack
273
Feb 10, 2020 10:23 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
jDt!
Oct 2, 2015 04:04 PM
Digitz0070
Sep 27, 2015 07:49 AM
