Front Door Pannel Removal?
Old Jun 17, 2008 | 08:46 PM
GotBass's Avatar
Still plays with cars
Question Front Door Pannel Removal?
I have a dent in the passenger side door, which I am going get removed by a paintless dent repair guy. It worked great the last time, he took out three dents all in the rear doors.
Anyway I need to remove the inside door pannel so that the he can get to the inside of the door. Getting the back pannel out was pretty easy but the front looks to be a bit more tricky. So far all I have done is remove the plastic around the door handle and I cannot figure out where to go from here. If anyone has removed the pannels for PDR or changing speakers or whatever could you give me any tips on how to remove. BTW, I did try searching but came up with nothing.
Old Jun 17, 2008 | 09:39 PM
DOMINION's Avatar
I don't buy Kool-Aid
There are some screws around the door and just remove the tweeter cover with your hand and take all the screws out. There is one in the door pannel pocket. To remove that screw you will need a long philips screw driver. After you remove all the screws its Cake
PM me if you have any questions.
-Gil
Old Jun 17, 2008 | 11:19 PM
Juice's Avatar
I made some poos
First off, roll your window down, it will make this entire thing easier
There are 3 screws:
Screw 1 is behind the door handle. It has a little cap on it. After the screw is out, you can remove the door handle trim
Screw 2 is in the pocket of the door, like Dominion said, you need a pretty long philips head screwdriver to get it.
Screw 3 is the trickiest. You have to remove the window switch panel to gain access. To remove that you need to pry it up from the bottom with a small flathead screwdriver. Disconnect the switch connectors and set the entire panel aside. Once it is off, you will see a gold colored phillips head screw.
After the 3 screws are removed all that is holding the panel on is a bunch of plastic connectors that just pop off. Start from the bottom rear corner (where the light is) and slowly pry up on the panel moving toward the front with a flatheat screwdriver or even a butter knife (cover it in electrical tape to prevent scratches). Then pry up the sides. Lift up the panel to remove it from the window frame. Reach in and disconnect the courtesy light and the light that shines down on the window/door switch area.
Thats it, it is off. Just put it back on in the reverse order.
If the dent repair guy needs the window up, just reconnect the switches, turn the car to the on position and roll it up then shut the car off.
Old Jun 17, 2008 | 11:30 PM
DOMINION's Avatar
Ahh I forgets about the window switch panel screw lol
Old Jun 19, 2008 | 02:25 PM
GotBass's Avatar
Ok, I got the outer pannel off. And now there is an inner plastic pannel, with the speaker and what I assume is the side impact sensor for the airbag system. Have you guys taken this off as well? I am not crazy about messing with airbag sensor parts, I have heard bad things from friends that work on cars (although nothing on the 8). There are two plastic plugs in this pannel which I removed which give a bit of access to the outside pannel, not sure if it will be enough for the guy to work through.
Old Jun 20, 2008 | 07:39 AM
BBQdDude's Avatar
BBQ Smoker Addict
Not sure if this will help but it goes over a lot on teh door panel removal and other parts. This is form the puddle lights install...
http://rx8.becomeanidiot.com/puddlelights.pdf
Take care,
Brian
Old Mar 1, 2009 | 12:46 PM
Myztiq's Avatar
i need to know how to remove the rear door panel the half door lol
Old Mar 1, 2009 | 12:50 PM
G3tR3DDY2GR3DDY's Avatar
the pull handle cover pops off. look for the seam and pull on the outer part. then there are two screws underneath that.
take the screw out of the actual door open handle bezel. then pop off the rest
Old Mar 1, 2009 | 01:18 PM
Myztiq's Avatar
are the screws were like the half door window is at there are 2 silver ones
Old Jun 15, 2012 | 01:22 PM
<ARRXATE>'s Avatar
Black on Black
There are 3 screws:
Thank you! this helped me out a lot! [= That screw in the pocket... Lets just say that screw and i dont get along.
Old Jan 18, 2015 | 01:53 PM
emerodi8's Avatar
Hey all
I made a video to help with removing the front door panel. Please share if this was a bit of help. Link below
http://youtu.be/mP4Wt1YzASQ
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
blkswan
West RX-8 Forum
Oct 24, 2016 11:34 AM
MarkX
Jul 31, 2015 07:50 AM
