lower intake observations
Old Jun 16, 2008 | 10:05 PM
olddragger's Avatar
ok---in looking at the lower intake(off the car) it seems that the vdi and the secondaries are not precise. The vdi--if not positioned VERY particularly--actually can be partially open on one side. I would think that is not a good thing especially for the fi guys.
also the secondaries does not have a smooth transition within the intake. One side was good, it was smooth etc, the other side had a lip big enough to stop a screwdriver as it is following the curve in the intake. that has to create some turbulence,
i also saw some edging that could be smoother. Maybe there is some lower intake work that could be done. ?
olddragger
Old Jun 16, 2008 | 11:30 PM
rotarygod's Avatar
Yeah there is a little bit that can be improved. It's not perfect but it is night and day better than anything Mazda has ever put on a rotary before. You might get about a 5% or so flow improvement max if you correct everything. Just a guess though. It won't be much.
Old Jun 17, 2008 | 10:16 AM
olddragger's Avatar
Thanks RG
Have to admit i am not expecting a large difference from these possible little tweaks---but little tweaks add up and at times can be a big part of a package.
It really is a well designed unit. The biggest thing i wish for is less heat soak through this intake--have some ideas there also.
olddragger
Old Jun 17, 2008 | 12:35 PM
rotarygod's Avatar
Ceramic coat it inside and out.
Old Jun 17, 2008 | 07:13 PM
olddragger's Avatar
maybe outside--there is a coating to help shed heat--wish we had an heat isolation gasket also
OD
Old Jun 22, 2008 | 05:22 PM
olddragger's Avatar
Hey RG why are the apv runners a different length from each other?
olddragger
WranglerFan
Aug 21, 2022 01:29 PM
Jst4fun
Apr 17, 2021 07:43 AM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
