Rotars not covered by warranty
Old Jun 16, 2008 | 07:07 PM
zeblien's Avatar
general user
I am dealing with my only mazda dealership about an issue I have with breaking.
When I break at high speeds, like on the freeway, the car shakes, steering column shakes....
I have not made any hard breaks, or abused the car (25k miles) and I was under the impression that the break system was covered.
Can anyone give me advice? Will need to call Mazda Corporate to double check... doesn't seem right. Then again, this is my first new car.
Old Jun 16, 2008 | 07:12 PM
heyarnold69's Avatar
Rotary wanabee
sounds like you have a warped rotor. just get em cut... 10 bucks a rotor
Old Jun 16, 2008 | 07:17 PM
chrism's Avatar
Misfit Moderator TnC
brakes are a wearable item and wont be covered
Old Jun 16, 2008 | 07:25 PM
zeblien's Avatar
general user
Heyarnold... what do you mean get them cut?
The dealership quoted me $150 to grind them down. Do you mean slot the rotors?
DeViLbOi's Avatar
The devil made me do it
Yea...I agree with heyarnold69...get those things turned. With your mileage your are probably more than due. Take your car to a brake shop and they should do it for between 10 and $25 per rotor. And to answer your question. The rotors are put on a machine and spun while a very small amount of metal is removed from the rotor.
Old Jun 16, 2008 | 07:26 PM
jlf12345's Avatar
sadly this is true. best bet is to try and get them resurfaced, which wouldn't be too difficult if you are mechanically inclined. sometimes, even resurfacing the rotors wont fix them because they are TOO warped, in which case you would have to purchase new one. Best of luck to ya.
Old Jun 16, 2008 | 07:34 PM
Spinning Sushi's Avatar
I <3 Sushi
Hey zeblein, you spelled brake, brakes, braking, and rotors wrong.
Anyways, just have your rotors resurfaced and your braking will feel smooth again.
Old Jun 16, 2008 | 07:47 PM
Revvittupp's Avatar
Only the non wear and tear brake items are covered... no pads, rotors, drums or shoes on any car that I know of(BMW has free maintenance and thus seperates the coverage). Caliper's, Master cylinders and maybe a few more components are covered.
Old Jun 16, 2008 | 08:11 PM
b'Eight''s Avatar
cutting rotors is old school
Just replace them. They are warped. By the time you cut them, the rotors are nearly out of spec and will needing replaced soon anyways.
Old Jun 16, 2008 | 08:13 PM
Huskyfan23's Avatar
It's called wear and tear, and it's never covered by a warranty or insurance.
Old Jun 16, 2008 | 08:39 PM
ShinkaTeen's Avatar
space reserved for shirt
idk what the problem is because im still a nooob to rotory functions cause noone really knows much to teach me.
but what i would like to know is. how the hell is ur shinka convertible?
Old Jun 16, 2008 | 08:42 PM
Socket7's Avatar
ಠ_ಠ
You could resurface them, but chances are they would just warp again in a several thousand miles and then you'll need to get new rotors anyways.
It's cheaper to just get new rotors. They're designed to be replaced.
Old Jun 16, 2008 | 11:16 PM
Get new ones.
Riding the brakes will warp them.
Jst4fun
Apr 17, 2021 07:43 AM
Oct 3, 2015 09:51 AM
SimonT182
Oct 2, 2015 10:33 AM
duworm
Oct 1, 2015 04:57 PM
