2005 rx8 manual trans performance spec?
Old Jun 15, 2008 | 05:33 PM
gregkelley's Avatar
What is the curb weight on a 05 rx8 and what id the 0-60 time? I have search the web and have come up with different times.
Old Jun 15, 2008 | 05:42 PM
depends on the trim, and the ability of the driver.
Old Jun 15, 2008 | 05:49 PM
CompMan's Avatar
iDüber
I'm sure a little searching can answer that question.
Old Jun 15, 2008 | 07:19 PM
gregkelley's Avatar
Trim? I am totally new to the rx8 not sure what you are talking about.
Old Jun 15, 2008 | 07:26 PM
chancejat's Avatar
Drive it like u stole it!
about 3000 pounds....0-60 depends on driver skill can be any were from 5.8-7.5 secs....
Old Jun 16, 2008 | 12:48 PM
gregkelley's Avatar
Thanks I found on the internet that an 08 rx8 does it in 7.5 sounded slow to what I had seen for the older models that is why I was asking.
Old Jun 16, 2008 | 12:51 PM
kersh4w's Avatar
Hit & Run Magnet
7.5? maybe the automatics.
the base model weighs the least, the sport weighs a bit more, and the grand touring weighs 100lbs (afaik) more than the base.
Old Jun 16, 2008 | 01:46 PM
RufusVonStorm's Avatar
I think it depends on how much you want to smoke your clutch and how good you are at launching a car where everything happens at high revs
Traction control off, rev to 5k, feather clutch and add power it takes some practice but the car can chirp/squeal away and get up to speed quickly
0-60 in the mid 6's or lower depending on skill and how mesquite you want to make your mazda
Old Jun 16, 2008 | 01:51 PM
JRichter's Avatar
Void Where Prohibited
I've seen 0-60's from 5.8-6.5 sec. R&T attachment says 5.9 sec.
Curb weights I've seen from 3029-3053lbs. R&T attachment says 3000lbs.
Road & Track test panel data:
File Type: pdf
Quato_jr
Aug 4, 2015 09:22 AM
MauiMazda2
Aug 3, 2015 02:47 PM
netrovers
Jul 20, 2015 03:32 AM
AussieGray
Jul 16, 2015 03:58 AM
