Coolant Change Interval Controversy
Old Jun 15, 2008 | 01:33 PM
RotoRocket's Avatar
Freely Radical
I was checking my oil, as I typically do every 10 days or so, and noticed that my coolant level in the reservoir dropped a tad. Not much, but enough to notice. It's still full.
Anyways, that got me thinking about the 60k coolant interval flush and refill as recommended in the manual.
I know, because I just searched, that a lot of my fellow 8 owners are doing the flush and refill every two years or even more frequently, using coolant plus distilled or de-mineralized water:
https://www.rx8club.com/showthread.p...=coolant+flush
Anyways, a lot of people think the manual is actually conservative when it comes to coolant interval changes. A lot of modern cars are designed to go much longer before needing one (GM and their Dexcool - I know, many reported problems).
Also, the rotary is heat generating machine - much more so than most coventional motors.
Here's my question: Does anyone here have an opinion on the ideal coolant and change interval with the 8 in moderate climates (midwest)?
Also, I haven't seen any recalls or TSBs regarding the factory setup on the coolant system? Have I missed any? I know there are some heat shield TSBs, etc., but I'm talking coolant or coolant system directly.
Thanks.
Old Jun 15, 2008 | 01:38 PM
2yrs on factory then every 2 yrs later as a minimum
I do mine a lot more....it's kinda like oil.....cheap insurance
New engines with a lot of aluminum and iron combinations like our engines...can have a lot of galvanic problems from the dissimilar metals if the coolant becomes depleted of the anti corrosion additives...or if it becomes compromised from crappy water ..
Old Jun 15, 2008 | 01:46 PM
RotoRocket's Avatar
Freely Radical
And you're using Mazda spec'd or OEM coolant on the changes?
Thanks.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Azki23
Jun 27, 2018 03:48 PM
tallestmexican
May 1, 2018 07:22 AM
Irvinb16
Sep 11, 2015 10:27 PM
