View Full Version : My 2JZ-GTE Swap (Lots of pics)
sixgen3sgte 06-10-2008, 10:15 PM Edit
UPDATE ON PAGE 4
first off, i do not know how much longer it is going to take me as i still have alot of parts to get
i'll post a bunch of pics and when i have more info on what all needs to be done and a full list of all the parts required for swap i'll post them, but for now these are all the details i have
here it is stock, right before i put on my new wheels and tires
http://carpron.com/multisite/d/165730-2/P1014364_001.JPG
after the initial turbo and body kit install
http://carpron.com/multisite/d/94593-2/P1014814.JPG
after Paint
http://carpron.com/multisite/d/104927-2/P1015089.JPG
http://carpron.com/multisite/d/104979-2/P1015064.JPG
http://carpron.com/multisite/d/102122-2/09.jpg
on the dyno (it made 249 whp, from 180 stock. which was a little disapointing)
http://carpron.com/multisite/d/104942-2/P1014957.JPG
and one more shot, showing off the engine bay
http://carpron.com/multisite/d/102128-2/11.jpg
here it is now
http://carpron.com/multisite/d/207553-2/P1016403.JPG
and a couple pics of test fitting some nice big wheels
http://carpron.com/multisite/d/225020-2/P1017077.JPG
http://carpron.com/multisite/d/225023-2/P1017066.JPG
http://carpron.com/multisite/d/225026-2/P1017079.JPG
http://carpron.com/multisite/d/225029-2/P1017067.JPG
http://carpron.com/multisite/d/225032-2/P1017074.JPG
sixgen3sgte 06-10-2008, 10:16 PM here are some pics of the engine bay fabrication work i did
i did make a couple cuts, and of coarse i removed beam that connects the frames in the middle of the engine bay
http://carpron.com/multisite/d/207492-2/P1016064.JPG
ABS relocated (had to extend harness about 6 feet) (this is not required, the 05 model has a smaller ABS module, but this does make it look alot nicer.
http://carpron.com/multisite/d/207495-2/P1016026.JPG
Front support and radiator/intercooler mount
http://carpron.com/multisite/d/207514-2/P1016306.JPG
http://carpron.com/multisite/d/207520-2/P1016350.JPG
http://carpron.com/multisite/d/207532-2/P1016366.JPG
http://carpron.com/multisite/d/207535-2/P1016372.JPG
http://carpron.com/multisite/d/207541-2/P1016394.JPG
http://carpron.com/multisite/d/207550-2/P1016401.JPG
the motor, turbo and parts (sorry for the crappy pics, i haven't brought my good camera to work yet)
http://carpron.com/multisite/d/222230-2/IMG_0125.jpg
http://carpron.com/multisite/d/222215-2/IMG_0094.jpg
http://carpron.com/multisite/d/222233-2/IMG_0126.jpg
http://carpron.com/multisite/d/222245-2/IMG_0135.jpg
http://carpron.com/multisite/d/222242-2/IMG_0133.jpg
http://carpron.com/multisite/d/222239-2/IMG_0132.jpg
http://carpron.com/multisite/d/222236-2/IMG_0129.jpg
sixgen3sgte 06-10-2008, 10:17 PM I finaly got the car to my work a few days ago and sat the motor in today
I will not have to cut the firewall, unless i want to to sit the motor alot further back. as of now until i get the tranny, as far as i can tell from measurments i have aquired online i will have to lengthen the shifter to go into the stock location
I may also use aftermarket electric fans, as the stock ones come very close to the crank pully.
here are some pics of the motor sitting in the engine bay
http://carpron.com/multisite/d/224933-2/P1017131.JPG
http://carpron.com/multisite/d/224936-2/P1017132.JPG
http://carpron.com/multisite/d/224939-2/P1017133.JPG
here you can see how close it is to the radiator fans, and why i will probably go with thinner fans, possibly even pushers
http://carpron.com/multisite/d/224942-2/P1017134.JPG
http://carpron.com/multisite/d/224954-2/P1017151.JPG
http://carpron.com/multisite/d/224948-2/P1017142.JPG
i have about a 1/2 an inch between the motor and firewall, i did beat it in a little before painting it, but thats it, the water line coming out of the back of the head will have to be modified slightly
http://carpron.com/multisite/d/224945-2/P1017140.JPG
http://carpron.com/multisite/d/224951-2/P1017148.JPG
more to come soon
i'm using a R154 tranny, and getting a custom driveshaft with the stock diff for now, i want to test it out anyway to see just how much power it can hold, if can get it to hold 450 to 500 i will prolly just throw in a kazz or cusco lsd, mabey even a mazdaspeed, and see how much that can hold, if it does break i will most definately go with one from another car, but i do not know what yet. i'ld like to go with a supra diff but they are really high, i might get a ford 8".
i won't be pushing more than 300-350 whp when i fist get it running because i want to show the car at nopi nationals and i need tmake sure its going to be running for the show, so i won't be able to afford it if it breaks. as soon as i'm back though, i will start upping the boost
i am still waiting on R154 tranny, flywheel, clutch, usdm MKIV supra oil pan, USDM supra water pump, injectors, adjustable FPR, Piping, Wastegate, BOV, timing belt, acc. belt, and lots of other small misc parts
and i have alot of wireing yet to do
and yes i did polish the intake manifold and valve covers myself. i am the only person to touch this car besides paint, which need redoing in alot of places and will be when the motors in.
ive done all the wireing, fab work and engine detailing.
Moostafa29 06-10-2008, 11:16 PM I love the way your car looks, except for the stock spoiler. Good luck on your build, and please come back and update.
alz0rz 06-10-2008, 11:21 PM holy moly!
romycha1 06-10-2008, 11:32 PM Sweet. I love it... I'm sure you're gonna get a few haters in here. Hopefully you'll be able to finish this. I remember the last 2jz thread... I don't think the guy ever finished it.
XDEEDUBBX 06-11-2008, 07:03 AM thats nuts man..good luck
StuttgartRX8 06-11-2008, 07:55 AM thats badass
tdiddy 06-11-2008, 09:28 AM Look'n very good. One question tho, why not go with a V-mount setup since you already have the front end torn apart like that? You could probably make more room for the radiator fans and crank pully that way too.
sixgen3sgte 06-11-2008, 09:45 AM yeah i'm sure there will be some, i was already expecting that
i'm sure some will talk about weight balance, and how its not a rx8 without a rotary, but i'm not build it to track race, i want a good street car i can wax some cars on the highway with but something i can also slide around, and i really think i will be able to do that with this car
and i did not buy the car because of the rotary, i bought it becasue its a really great looking car, and its not as common. it also has one of the smoothest rides out there, this thing is more stable at 150mph than a Z is at 120. andi promise, with the amount i paid for the car, and the amount i will have in it, i would barely be able to afford a stock supra, and it will be just like every other stock supra, i will have a one of kind car when its done. and it should be a good bit lighter than a supra too.
as far as V-mount, there is definately no room for that without moving the motor about a foot back and getting different radiator and intercooler.
v-mounts take much more room from the front bumper to the motor
sixgen3sgte 06-11-2008, 02:30 PM i posted this on the supra forums also, and have had alot of feedback, and jsut posted this info on there, so i am post it on here too
thanks for all the comments guys
and yeah it will def be at nopi
i want it done by July 18 for a drift (practice only) event in atlanta that i really want to attend but IF it is done, it probably won't be drift worthy yet
I have the RX8's harness finished other than the EPS, and gauges
and i have done some 2J harness's before it just need several positive sources and several grounds. i'll be mounting the ecu under the dash in, i just have to find the pinouts again
i just ordered the USDM MKIV oil pan, water pump and a bunch of gaskets and stuff today, they will take it out of my check for the next several weeks, but it will be here tomorrow
i also hopefully have a buyer for a 3sgte motor i have and that will pay for the tranny i'm buying from some one on the Supra forums, a wastegate (going with the HKS standard, so if you know someone with one let me know), clutch and flywheel
i still have to figure what i am going to do about the drive shaft, but can't do anything till the tranny is here.
i will make the mounts this week and next. looks like i'll be doing solid mounts, at least for now, and see how well i can tune the idle. i just don't think i have the time to fab, good urethane mounts and have time to test them. plus there is not much room between the cross member and oil pan or plug cover and hood, only about 3/4 of an inch total, mabey more but i won't know till the new oil pan arrives
i've got the charge pipes already, just may have to get some new boots if i want it to look good
i'll be dropping off my throttle body, intercooler, and some other small aluminum parts off at a local welders that i have been using for aluminum parts for years
that should be ready early next week and then it will take me a few days to polish all of it
I also have to fab the down pipe and exhaust, i'll prolly just get a vband and use 3" steel pipe, i don't know if i'll be able to get mandrel yet, but thats something simple enouth to change later, and it will have wrap so you won't be able to see it
i want to get a supra down pipe and see if it fits, it looks like there is room, and at worst it would have to be slightly modified but i prolly won't have the extra money by then.
i also have to figure out what i want to get for tuning. i have a AFC neo worst case
but i want the AEM fuel/ignition controller
but anyways thanks again for the support guys
WVBoosted8 06-11-2008, 02:44 PM Good luck man, I cant wait to see it. BTW I'm not really into body kits but yours looks nice, what kit is it and who makes it. Thanks
WoodsOfGreenRx8 06-11-2008, 03:59 PM i also have to figure out what i want to get for tuning. i have a AFC neo worst case
Check into Haltech for ECU options also. They have some good products. My boss who just tuned a G35 with one liked it quite a bit & is doing another one for a 350Z.
Nice car & good luck
sixgen3sgte 06-11-2008, 05:23 PM Check into Haltech for ECU options also. They have some good products. My boss who just tuned a G35 with one liked it quite a bit & is doing another one for a 350Z.
yeah haltech is a very good ecu but they are also very expensive. i can get an AEM alot cheaper
krijpipudht 06-11-2008, 05:47 PM Wow, IT DOES FIT....
I love 2Jz. It is really tough engine.
May be we can see 600+HP RX-8 for street, or 1000+HP for racing.
Goodluck!
Mad_kidd 06-11-2008, 07:42 PM Good luck man, I cant wait to see it. BTW I'm not really into body kits but yours looks nice, what kit is it and who makes it. Thanks
x2, but keep us updated man, i'm playing with idea in my head right now, but probably along the line of a 7m or 1jz
subscribed
SlideWayz 06-12-2008, 12:52 PM Oh why oh why oh why couldn't Mazda make 'em this way from the factory?
OK, maybe a turbo 4 cylinder even.
swoope 06-13-2008, 04:35 AM wondering how you are going to do the wiring. are you going to replace all the gauges with analog???
all forms of dsc and tc must be gone. also abs.. and good luck to you.
i think i would just have got a supra. i miss mine sometimes.. targa good! :)
beers :beer:
sixgen3sgte 06-13-2008, 11:12 AM wondering how you are going to do the wiring. are you going to replace all the gauges with analog???
beers :beer:
no its keeping abs, and possible dsc
and stock gauges will work
PRacing 06-14-2008, 03:55 PM Nasty bro, keep us updated. I'm subbing!
OneEvilRx8 06-15-2008, 05:43 PM All I Can Say Is Sick!!!!!
faboo 06-15-2008, 11:21 PM ur car is sick..whether it be a turbo reny or 2jz.....good luck with finishing it up
post as many pics as possible
Jedi54 06-16-2008, 12:40 AM whoa...can't wait to see the finished product
9krpmrx8 06-16-2008, 12:50 AM wow.
kersh4w 06-16-2008, 01:32 AM someone with a shot of actually doing a swap.
nice job dude. haha, you might end up getting hired to do a swap for taj once he figures out he cant put a 100 shot into a 13b. :lol:
Wow excellent , would really like to see this finished. And also maybe some info on how you accomplished the swap cause im interested. :)
cmr333 06-18-2008, 06:58 PM nice i have some competition lol. we so have to meet up and park next to eachother at the nationals
OneEvilRx8 06-21-2008, 04:59 PM Updates, updates.....!!!!!!!
lilturbododge 06-24-2008, 11:27 PM update...please!!
learycd 06-25-2008, 09:15 AM wow this thing can be a monster, what are your goals in terms of end power?
good luck with it
OneEvilRx8 06-28-2008, 09:42 AM Updates.......
RotaryFiend 07-06-2008, 04:50 AM :eyetwitch
It looks really good, I hope it turns out well.
In all honesty though, I hope it goes terribly and there are tons of electrical and fitment issues and it just doesn't work.
You'll feel a much greater sensation of self-actualization by figuring out the rotary :)
What do you plan on doing for the EPS and ABS?
sixgen3sgte 07-08-2008, 01:48 PM lol ^
i'll post info on the electrical issues as soon asi have them worked out, i haven't even really started on alot of things
i've been really busy at work, and have not been able to stay late like i would like to, i did tget the motor mounts made, and have started on the steering, i still have alot of work though, again i'm looking to get finished by september, im also taking the car back home this week, cuz i'm done with the lift for a while, just have some welding to finish up and the steering can be done with jack stands
Rootski 07-08-2008, 09:30 PM The 2JZ is not my cup of tea, but it's a very well planned and well executed swap you've got going there. Best of luck.
angeljoelv 07-09-2008, 12:48 AM What is wrong with people in FL?????
20B's, SR20"s, 2JZ"s whats next?
jajajaja
angeljoelv 07-09-2008, 12:49 AM nice i have some competition lol. we so have to meet up and park next to eachother at the nationals
Hey... Can I be invited????? or I dont qualify?
^ Lol i think you qualify. Fuckin california sucks , if i do a swap here they will crush my car because of mismatched vin numbers lol. Whats the laws in florida because i plan to move later on so i can do stuff to my car. California u cant really do anything here not even exhaust. Oh and i hope you finish this , any estimated on how much this is gonna cost you? Maybe this can be a 20b swap alternative :uhh:
cmr333 07-10-2008, 10:50 AM well in fl you can do pretty much anything you want to with your car. the only thing you have to worry about doing is making it know to somone if you try to sell it.as far as cost dont plan on it being cheap but it will probably be alot cheaper all the way around compared to a 20b
ciobulus 07-21-2008, 04:45 AM i've read 100 posts saying that this swap is the devil that you take the soul of the rx8 and you fwk up the weight balance and that all 2jz are crap and you cant get more than 400 rwhp out of it and even if you have a monster 2jz u cant run 9's ... but imho this is the best thing that rx8 can get ... first of all i have a rx8 and the first day i bought it i was with a friend that has a Opel Astra Cabrio Bertone 2.0 turbo (stock 200bhp) modded to ~280 bhp and 380 nm torque (not proven on dyno) and on the way back home we raced from 50 from 60 from 100 and from a stand still (KPH) he owned me with ease pulling ahead like i was standing still even from a stand still i could only get a car ahead of him for a short period of time i wanted to at least hang with him since a VW passat 2.0 DIZEL AUTO tuned could hang with him until 140 kph. That OPEL is allmost the same as the 1.7 astra ... same gearbox same FWD same backbone only the engine is changed and if a astra with a 2 liter small turbo 20 psi could kill a rx8 that easy then i want a better engine in mine and no mods could give me the confidence of reliability i feel that if slap a bolt on turbo on it it wont beat the astra and it will break down more offen so the only real option of modding a rx8 is a complete engine swap ... any1 who tells you otherwise is just ignorant. and those who flame about lag and stuff can try to go from 50 in second gear against a turbo astra in second gear and see what happens u have no power for a lot of time and the astra is already breaking in front of you
Dude i really dont get your post , use some damn commas or something ffs. If you're flaming the 2jz then you are a retard , thats one of the best engines imo , cant run 9's with it? Wtf are you talking about , those engines can produce more whp then you can ever possibly need , like 1500+? And dude , im not trying to bag on you or nothing but if you bought the rx8 for a drag car then you got yourself the wrong car. Yeah there is lag but theres also things like anti lag , brake boosting etc. 2jz rx8 would completely dominate a fucking astra or any crap ass VW. But yeah best way to get power out of this car is to do an engine swap sadly , its not getting rid of the soul imo you are just replacing it with a stronger heart so to speak :). Not everyone buys the rx8 because they are in love with the rotary , they might simply like the pricing , looks , and handling characteristics. Im buying a supra soon and then going bpu for awhile , unless this swap gets completed and shows good results...i might do it also after i move from shitty california.
ciobulus 07-21-2008, 10:14 AM i like the 2jz and i was saying that it is a good idea and that i dont like the ppl that flame it so you misunderstood
devildog1679 07-21-2008, 10:24 AM ^ Lol i think you qualify. Fuckin california sucks , if i do a swap here they will crush my car because of mismatched vin numbers lol. Whats the laws in florida because i plan to move later on so i can do stuff to my car. California u cant really do anything here not even exhaust. Oh and i hope you finish this , any estimated on how much this is gonna cost you? Maybe this can be a 20b swap alternative :uhh:
Even if you have receipts for all the purchases? I thought they only crush your car if you don't have proof of purchase?
faboo 07-21-2008, 02:35 PM Even if you have receipts for all the purchases? I thought they only crush your car if you don't have proof of purchase?
they have gotten crunch crazy lately:rant: :banghead:
cmr333 07-21-2008, 06:24 PM damn i love fl.
RotaryFiend 07-21-2008, 09:19 PM i've read 100 posts saying that this swap is the devil that you take the soul of the rx8 and you fwk up the weight balance and that all 2jz are crap and you cant get more than 400 rwhp out of it and even if you have a monster 2jz u cant run 9's ... but imho this is the best thing that rx8 can get ... first of all i have a rx8 and the first day i bought it i was with a friend that has a Opel Astra Cabrio Bertone 2.0 turbo (stock 200bhp) modded to ~280 bhp and 380 nm torque (not proven on dyno) and on the way back home we raced from 50 from 60 from 100 and from a stand still (KPH) he owned me with ease pulling ahead like i was standing still even from a stand still i could only get a car ahead of him for a short period of time i wanted to at least hang with him since a VW passat 2.0 DIZEL AUTO tuned could hang with him until 140 kph. That OPEL is allmost the same as the 1.7 astra ... same gearbox same FWD same backbone only the engine is changed and if a astra with a 2 liter small turbo 20 psi could kill a rx8 that easy then i want a better engine in mine and no mods could give me the confidence of reliability i feel that if slap a bolt on turbo on it it wont beat the astra and it will break down more offen so the only real option of modding a rx8 is a complete engine swap ... any1 who tells you otherwise is just ignorant. and those who flame about lag and stuff can try to go from 50 in second gear against a turbo astra in second gear and see what happens u have no power for a lot of time and the astra is already breaking in front of you
Irony?
Maybe English is your second language? If so, the definition of ignorant is not knowing. As in, you are ignorant of the rotary engine, and quit street racing dumb shit.
Turbo rotaries have plenty of low-end.
xsnipersgox 07-21-2008, 09:34 PM i've.. i am stupid ... front of you
do not disrespect the astra, there is a reason why they are liked, very very light weight.
now, do not disrespect the rotary, rotary engine sacrifice torque for power per displacement/engine room. there is a reason why for the same room this guy is doing, he can shove 3, 4 rotor in the car and get crazy hps... un boosted...
finally, and no flame please, whats the same between a 800,900,and 1000 hp supra?. ... they all run 10 seconds.
cmr333 07-21-2008, 10:07 PM and destroy tires with no remorse
RotaryFiend 07-21-2008, 10:21 PM and destroy tires with no remorse
yeah, shred-tacular........
^^ Atleast you look cool when you hit the wall on the 1/4 mile run. rofl. Yeah and i heard they crush cars EVEN if you have reciepts for the purchase. California really hates "illegal" modifications and they show it by unconstitutional aggression. I say we all start a riot , in the midst of chaos i will search for a 3 rotor in a shop to loot :). Of course this is for the common good.
ciobulus 07-22-2008, 10:06 AM supra runs 8 with a 6 gear manual tranny and yes english is my second language and. Theres nothing between a 800 900 1000 rwhp supra coz u are on the edge of grip at 700 hp so with 800 bhp 900 1000 u need drag slicks suspension line locks and other mods for the quarter mile ... The reason behind the 1000 bhp 10 second run is that they are daily driven and all around tuned not focused on drag racing. And what the fuck is wrong with 10 seconds ? veyorn cant hit 10 seconds on the drag strip. i like the engine its a cool engine but i hate the fact that it breaks down a lot, yesterday i went to buy some oil from the mazda dealership and the guys there started telling me to reserve a engine from austria coz mine at 33k Km will fail soon :) so what the fuck pay 5 thousand euros for a new rotor and housing or just swap it with a 2jz NO BRAINER
Edit : i get the guys that flame openminded ppl like me .. when i was 16 i would punch someone in the face if they sayd that theres a engine that is better engineered and better built than my 1.3 L 80 kw lancia engine :)) and my friend with the astra which i like a lot (someone assumed i hate astra) argued with me day and night about dizel engines being the best engines in the world. You will get it soon and swap rolls royce turbine helicopter engines in your mazdas if it puts a smile on your faces.
raise your hand if you heard about a small car called Shelby Cobra . Guess what that car is a AC ACE roadster with a V8 swap form a inline 6.
So maybe if i do this swap i'l run it against a stock rx8 on the track to see which is more fun to drive and own since i hear that most of the rx8 owners spent more than 40 grand on they'r cars to run 360 bhp and they still break down every now and then.
angeljoelv 07-22-2008, 03:39 PM 40 grand for 360 HP???? where did you hear that?????
Rootski 07-22-2008, 03:45 PM You will get it soon and swap rolls royce turbine helicopter engines in your mazdas if it puts a smile on your faces.
Shit, I'd do that now.
VarneyMazda 07-22-2008, 03:57 PM 40 grand for 360 HP???? where did you hear that?????
maybe with the exchange rate.
cmr333 07-22-2008, 04:03 PM Somone Struck A Nerve Lol
tajabaho1 07-22-2008, 10:44 PM more like struck a wad of cash
chrism 07-22-2008, 10:52 PM and i thought i rambled
Yep with that much power traction is a bitch. The only reason to get more power then that is to hit the highway and do some pulls. Its not all about 1/4 mile lol , what about roll ons. Oh wait i must not speak of street racing :). Imo cobras are one of the sickest cars lol. Damn this thread went off topic. Need updates on swap please :(
angeljoelv 07-24-2008, 03:22 PM Well I can assure you that with 40G's you can get a Whole lot more than 360. But hey thats just my thoughts.
40g's if you buy a brand new rx8 +mods , then yeah.
rgonza 07-25-2008, 07:59 AM Mazda RX8 with auto tranny
http://www.youtube.com/watch?v=x72CH3VPqW8
ciobulus 07-25-2008, 09:14 AM yes 40g with the car .. but think about this ... i live in europe so .. il give you an example from where i stand, I can buy from germany an rx8 with lots of miles coz only the engine wears out (the roads there are perfect) i can buy it for 10k euros with a working engine and all the options i can just drive it around (not like a mad man) till it breaks and it will and then drop 10k more in it and swap it to a good 2jz engine (no mods) so 300 bhp at first few minor tweaks and tunes and ur in the 400 range for the price of a used good condition RX8 and u have the "reliable as the sun" toyota engine ... install a 2step and scare ppl shitless. As a every day car you cant drive the rotary engine like its meant to be driven, you need to rev it and keep momentum to get any kind of speed and fun but when ur in the city or outside the city there no fun to be had coz u will stop and break a lot so if u had a monster 2jz u'l be more than happy to stop and break coz you can spool that mofo back up and get pushed back in the seat.
Rgonza is that your rx8? That is freakin sick. Didnt know it was an automatic tranny until that video.
rgonza 07-25-2008, 10:50 PM yes is auto tranny . is recently installed. 3500 rpm converter from FB Performance & Protorque.
Regards
Rgonza:)
lilturbododge 07-27-2008, 12:10 AM yes is auto tranny . is recently installed. 3500 rpm converter from FB Performance & Protorque.
Regards
Rgonza:)
nice car!!! quick and sick!! how do you get the car to shift sooo fast!! thanks!
ciobulus 07-27-2008, 06:59 AM update on the swap ? plix
rgonza 07-27-2008, 08:27 AM It shift so fast due to a shiftronics units, Like Ferraris,Lambo, Steering Wheel Paddle Shift mounted . time between shift is 380 ms.
ciobulus 07-27-2008, 08:29 PM wow 380 ms thats boring ... get a CVT next maybe thats better u'r shifts will take 0 ms and not eat 30 bhp just to make the gearbox work
angeljoelv 07-27-2008, 09:18 PM I got lost ciobulus....
rgonza 07-27-2008, 10:34 PM hi,ciobulus Maybe your astra or your diesel VW or green car run good with a CVT unit, but here we're taking about 980 real RWHP @10200 RPM does you inmagine what happen when it apply all that's RWHP to your CVT :lol2: :lol2: :lol2: :lol2: :lol2:
zaksblaklabel 07-27-2008, 10:45 PM subscribed
angeljoelv 07-28-2008, 12:27 AM wow 380 ms thats boring ... get a CVT next maybe thats better u'r shifts will take 0 ms and not eat 30 bhp just to make the gearbox work
If that is boring to you..... I guess now we all now have extremly high expectations of your supercar coming up. Cant wait to your project finish so you can delight us with your nonboring transmission. Cant wait...
cmr333 07-28-2008, 12:47 PM +1 Lol ^
To each their own... I personally dont like shift tronic/auto trannies because i feel less involved when driving. Thats just me though , id rather have a 6 or 5 speed gearbox with a short shifter on it :). When i get a little older ill think about auto trannies lol :). Or when traffic gets really bad :(
ciobulus 07-28-2008, 08:43 PM everything is good its just a matter of perspective .. some like to grab the shift knob and ram it in gears like a bad ass mother fucker and some like to watch the revs go up and down while the car is moving in a smooth and amazing way. i like teh stick coz its another way to control the car from your body No wonder bikers have so much fun and love to just ride anywhere any pretext any day any time ... they just love it because they control every movement of that bike with the body and the mind ... not the mind of a german who made a new drive between the lines autopilot and 10 ms auto manual shiftmegatropix and the new just enter the car stfu and watch some commercials while i get you where u want to be. u dont see ppl getting the auto girlfriend fucker coz they want to do it themself's . Thats just my opinion and some ppl like both .. If u like both then ask the guy sitting next to you in the car to shit for you, i allways do that with my friends and we are used to it like even drag racing from stop signs while eating :))
romycha1 07-28-2008, 11:11 PM Damn dude, learn to use a comma.
angeljoelv 07-28-2008, 11:15 PM Just a reminder guys or to clarify... Its not a regular automatic transmission, It wont shift up or down unless you actually either move the stick or press the paddle. There is no drive gear for old people. So trust me its as much fun as a manual but you wont miss any shifts.
romycha1 07-29-2008, 01:00 PM Is that the tranny from CRH?
cmr333 07-29-2008, 02:02 PM :offtopic: WOW werent we talkin about 2jz's and rx8's and stuff?
This may have been asked and I missed it. How does it handle now? I'm sure you can tell a difference, but im sure it's awsome.
romycha1 07-29-2008, 09:30 PM This may have been asked and I missed it. How does it handle now? I'm sure you can tell a difference, but im sure it's awsome.
Who's car are you asking about? Angel's or Sixgen's?
angeljoelv 07-30-2008, 12:18 AM RGonza's I think...
ciobulus 07-30-2008, 06:56 AM i cant wait to get my hands on some 2jz rx8 footage and i hope noone else is doing a 2jz swap so it will be more unique than having a rotary engine :)
romycha1 07-30-2008, 09:56 AM There are a few 2JZ 8's running around already, I think CRH said he has his axles on one of them...
cmr333 07-30-2008, 12:05 PM im still the only one with an sr20 though
romycha1 07-30-2008, 12:11 PM You know.... I had an EJ20 (WRX) sitting in my garage for the longest time, that I fantasized about being in my 8.... I really wish that I had the testicular fortitude to try and swap it in.
Wow theres an rx8 thats up and running with a 2jz? Never seen it before. Wonder how much that swap costed him? I might consider doing a 2jz swap , love the sound of the inline 6. It also depends on the price though. Of course this thread is off topic , its pretty much dead. Wheres the updates on the swap?. Yeah.. Wow an auto tranny that doesnt shift until you tell it to. Sounds very interesting. How much did it cost to swap it in? Did it bolt right on to the 20b? Or did it require some custom fabrication? Interesting :)
ciobulus 07-31-2008, 07:39 AM im still the only one with an sr20 though
Did you finish your swap ? or what ?
OneEvilRx8 08-08-2008, 10:27 PM any updates on this swap?. anyone....
Nope no updates lol , this is what usually happens with engine swap threads.
cmr333 08-08-2008, 11:25 PM ouch...well i will be done with mine by the end of this month provided all my funds come through.
Lol , when your car is done be sure to take ALOT of pics and videos. Ill be your number 1 fanboy >_>. Oh and you have to let me drive it , thats the common rule for being a rx8club member. Yep read the rules. Section 24-A states when doing a Sr20 swap into the rx8 , you must give all rx8 members an equal and unbiased opportunity on test driving the vehicle per user satisfaction :). Damn look at me , im like a "forums Law" encyclopedia. They should make me an admin. Oh yeah and unbiased opportunity means giving even tajabaho a chance lol.
Asmoran 08-09-2008, 03:36 PM Luckily for CMR that rule doesn't apply to him, since he swapped in a sr20 not a 2jz.
cmr333 08-10-2008, 11:43 AM i will gladly let somone test drive my car, with me folowing behind them in there car with a large cash deposit.lol
OneEvilRx8 08-22-2008, 07:43 AM Damm, this suck!, still no updates....
sixgen3sgte 08-22-2008, 07:53 AM yeah sorry guys
i have gotton alot done in the last few weeks, but still waiting on parts
i have been trying to get the engine bay perfect
its been raining everyday here so as soon as i get a good sunny afternoon i'll do one last good sanding and then wash it and paint it
the stearing is done, and motor mounts
i'm still waiting on my 1jz bellhousing as well as quite a few other things, so hopefully i will be able to drive it to nopi in 4 weeks
as soon as she's painted i'll post new pics
cmr333 08-22-2008, 10:45 AM howd you do the steering? pics?
sixgen3sgte 08-31-2008, 10:58 AM sorry for the dealy here is the long awaited update
the weather has really slowed me down here
i also have most of the engine parts detailed and will have pics off all of those and the motor going togther and in the car for the last time within the last couple days
http://carpron.com/multisite/d/252840-2/P1017191.JPG
http://carpron.com/multisite/d/252843-2/P1017201.JPG
http://carpron.com/multisite/d/252846-2/P1017177.JPG
http://carpron.com/multisite/d/252849-2/P1017178.JPG
http://carpron.com/multisite/d/252852-2/P1017182.JPG
http://carpron.com/multisite/d/252855-2/P1017204.JPG
http://carpron.com/multisite/d/252860-2/P1017227.JPG
http://carpron.com/multisite/d/252863-2/P1017228.JPG
http://carpron.com/multisite/d/252866-2/P1017229.JPG
http://carpron.com/multisite/d/252869-2/P1017231.JPG
http://carpron.com/multisite/d/252872-2/P1017294.JPG
http://carpron.com/multisite/d/252875-2/P1017296.JPG
http://carpron.com/multisite/d/252878-2/P1017298.JPG
http://carpron.com/multisite/d/252881-2/P1017299.JPG
http://carpron.com/multisite/d/252885-2/P1017300.JPG
http://carpron.com/multisite/d/252888-2/P1017302.JPG
http://carpron.com/multisite/d/252891-2/P1017305.JPG
http://carpron.com/multisite/d/252894-2/P1017307.JPG
sixgen3sgte 08-31-2008, 11:19 AM Also can a mod please clean up this thread
i would appriciate it if you could remove everything not pertaining to the 2jz swap please do not remove any of my posts and people asking questions about the swap
but you can remove this post at the same time thank you
cmr333 08-31-2008, 03:22 PM nice work. the weather has been killing me to, and money as well. cant wait to meet up and see it in person.
OneEvilRx8 08-31-2008, 04:53 PM once you're done, are you going to do anymore swap like this? if so post price's soon.
sixgen3sgte 08-31-2008, 09:23 PM nice work. the weather has been killing me to, and money as well. cant wait to meet up and see it in person.
yeah me too, how far along are you. will yours be at the nopi nationals replacemnt show at the gicc. mine will it just sucks there isn't a rx8 only class
absolutely, i would love too
once i get the thing running i am going to poast prices of everything i had to buy and give a price i will do the swap for and details of how it will work, as in how much up front and who will get what parts i will do the first few to build up the swaps cheaper but prices will vary according to what kind of used parts each person can find or i find for them durring that particular swap
YaXMaNGTO 09-01-2008, 12:30 AM Awesome. It would be a shame to have that engine in a crappy looking bay... it has a nicely appointed home to live in now.
cmr333 09-01-2008, 05:14 PM im close but i think im going to be running by the end of the month. with all the craziness of work not being busy, moving, and all the goodness of life my project has been taking much longer than i ever wanted it to. ill bee running but i dont know about show quality just yet. i have alot in store for the car its just going to take a bit longer.
sixgen3sgte 09-02-2008, 02:24 AM im close but i think im going to be running by the end of the month. with all the craziness of work not being busy, moving, and all the goodness of life my project has been taking much longer than i ever wanted it to. ill bee running but i dont know about show quality just yet. i have alot in store for the car its just going to take a bit longer.
are you going to the nopi nationals replacemnt show on september 20 and 21 at the GICC not the atlanta motorspeedway
also can a mod please please clean up this thread i could not seam to find a mod to pm about this
cmr333 09-02-2008, 01:06 PM DOUBTFUL i have a wedding to go to on the 22nd...blah! ever figure out any eps wiring? and are you going to be making a custom sway bar, mines almost finished.
sixgen3sgte 09-02-2008, 02:31 PM That sucks. And no I haven't done any eps wireing all of the stock wires will be going to it I do not know how it works wether from trans speed or wheel speed sensors so I will see if it works and if not I will go from there. Alot of mine will not be done for the show. Such as gauges, ac, the sway bar etc... I will just have done what's required to move the car petty much. It's posible I will have to push it in. I'm guesing a month or two before it's at full speed making the power I want
OneEvilRx8 09-02-2008, 03:53 PM yeah me too, how far along are you. will yours be at the nopi nationals replacemnt show at the gicc. mine will it just sucks there isn't a rx8 only class
once i get the thing running i am going to poast prices of everything i had to buy and give a price i will do the swap for and details of how it will work, as in how much up front and who will get what parts i will do the first few to build up the swaps cheaper but prices will vary according to what kind of used parts each person can find or i find for them durring that particular swapThanks, keep me posted.
OneEvilRx8 09-15-2008, 11:07 PM nothing new yet?
RockTown07 10-02-2008, 05:19 PM Is this beast running yet?
sixgen3sgte 10-07-2008, 01:35 AM hey guys, sorry i haven't been on lately
trying get all the kinks worked out
i had a problem with the tranny i bought and still working on getting the gauges to work, if i can get my tranny back this week, i may have video footage of the car running this weekend
for updated info and pics of the car please visit the link to my myspace page in my sig
I got my wife to make a page for the car and i have been trying to get it going the last few days
i have some pics of the (nearly) completed swap at motorsports nationals car show (the nopi replacement)
ducttape4054 10-08-2008, 06:22 PM dude u gotta get it to work. cuz i will pay u and ship it to u to do mine!
tht gonna b one hell of a beast
YaXMaNGTO 10-10-2008, 01:49 AM hey guys, sorry i haven't been on lately
LOL!!! A connecting rod for the shifter! Killer...
http://c3.ac-images.myspacecdn.com/images02/54/l_6dbe09bb34cd497f927b0c1c8a2721aa.jpg
rockle3 10-29-2008, 08:17 PM updatessssssssssssssss?
jiggawha1 11-08-2008, 06:01 PM Bump Update!
Daemos 11-09-2008, 04:42 PM How is handling affected?
Brettus 11-09-2008, 04:52 PM handling has been pretty good - stays planted - in the garage lol
sixgen3sgte 11-22-2008, 12:00 PM yeah handelng hasn't exacty been tested yet lol
i got my fuel system worked out i think ill prolly get some picks of that up soon with some other i took while i have been wireing
i extended the 2jz harness several feet and was going to move it to the other side of the dash but decided to mount it under the driver seat for easier access
still working on getting it wired up correctly i am having trouble getting the ignition power
but luckily i have sold a few things lately so i have some extra cash.
first thing i am going to do is set up a phone apointment with DR Tweak of Phoenix Tuning for him to walk me through which wires actuall need power and ground on the harness
hopefully i will be able the crank the car after that we have discussed and he feels confident it won't be very difficult
also monday my driveshaft will get dropped off to be shortened and balanced
I got a drivesahft from my work that i think is off of a 4-runner, but it slides into my transmission perfectly and i have done some work to the diff end to get it to bolt up to the rx8 diff and be centered, it only needs to be shortened by about 3 inches, but i will be getting a custom aluminum driveshaft made from driftmotion later on.
i will try my best to get some pics up this weekend though
thanks to everyone who has been keeping up with this project.
ZumnRx8 11-22-2008, 12:55 PM What is wrong with people in FL?????
jajajaja i seen ur build, i hate u and ur car and florida, sons of B;s, Ill trade u for mine? lol? 20B is the ultimate monster! I seen the vids of ur monster, i'd kill every vette out there alive. ur lucky!
chrism 11-22-2008, 01:12 PM first thing i am going to do is set up a phone apointment with DR Tweak of Phoenix Tuning for him to walk me through which wires actuall need power and ground on the harness
tell josh chris previously from netuners said whats up...i helped get him blown up with a project called hellish mantis :)
RockTown07 02-14-2009, 11:46 PM How is this swap coming along?
Mspeedpro 02-15-2009, 11:37 PM No kidding, very interesting swap.
sixgen3sgte 02-16-2009, 01:28 PM yeah im in the same boat as cmr333 with the sr20 swap. NO CASH
its also been hard not having a heated garage. working in the cold sucks
but i should be able to jump back on it in the next couple of weeks.
i have gotten the fuel lines finished up, still need an inline fuel pump. and i think i have the drive shaft figured out, as well as the tranny and diff mount.
will try and get some pics up soon. i know all the ones i had got removed from my image archive for some reason.
romycha1 02-17-2009, 04:17 AM I know cmr333 was having EPS problems... were you able to figure that out?
cmr333 02-17-2009, 06:04 PM yeah man were in the same boat. i just sold my beeter and picked up an mr2 that i am reviving with free parts for my dd. after were done with our swaps with should have a bastard child rx8 meet lol
callan 11-12-2010, 09:11 AM Im 20 and have my 8 paid off... ive rebuilt motocross bikes into monsters and decided to finally get into cars... ive been looking for someone who put either a rb or 2jz engine into their 8 and i finally found it. youre a fu<king god. must see video!!!!!!!!!!!!!!! how much for you to do mine:D hahaha
fuztupnz 11-12-2010, 09:16 AM :scratchhe almost 2 years since the last update man. Good thread bump though.
and here we go again :crying:
If you have to ask how much, you can't afford it.
callan 11-15-2010, 09:06 AM If i had kids, id sell them.
