Stereo panel stays illuminated?
Old Jun 4, 2008 | 02:53 PM
champi0n's Avatar
Stereo panel stays illuminated? **update with pic**
I tried a search but couldn't find anything, so either no one has had this problem or i'm using different words.
But the Stereo panel in my 04 GT stays illuminated (every single possible light) when i turn on the car. (Sometimes it starts normal and stays normal, other times it returns to normal after about 10 minutes).
Know what I mean? So instead of seeing the radio station i'm on, each of the blocks is lit up. The time says 8888, temp 88, etc.
Old Jun 7, 2008 | 12:55 PM
champi0n's Avatar
Here is a pic of what happens.
It stays like this most of the entire drive (15-20minutes)... sometimes it goes normal again.
Last night when i turned off the car to take a pic (leaving in the ACC position), i put the window up, noticing a dim of the lighting slightly being able to see what's supposed to be there. With both windows up and pulling up on both window switches, it dimmed even more - though the effect of lights was still there.
So i'm not sure what the problem would be exactly.... a fuse providing too much voltage to the illumination wire? faulty equipment?
Old Jun 7, 2008 | 02:25 PM
JRichter's Avatar
Void Where Prohibited
I remember reading about someone else having this problem a while back but couldn't find the thread. If your desperate for answers try the dealer.
Old Jun 7, 2008 | 03:37 PM
EdwardsB's Avatar
Registered RX-8 User
I know this does not help you out, but should the fan intensity icon in the stereo panel light up? Since I got mine it has never lit up and I just figured it was because they used a generic panel for all their cars and some use it while other models dont.
Old Jun 7, 2008 | 06:47 PM
Renesis07's Avatar
Vtak just kicked in yo!!
From what I've read, its caused by heat. The sun beating down on your dash. I don't know if thats true though
Old Jun 7, 2008 | 08:09 PM
there's another recent post with this problem and they recomended a battery.
Then I think there was another one in the last month.
Try a search, maybe they will have an answer.
Old Jun 8, 2008 | 02:46 PM
champi0n's Avatar
I tried searching but the terms don't bring up any relevant results.
I'm doubting its the sun (parked in garage), and I doubt it's the battery (Doesn't make electrical sense). But you never know.
Old Jun 8, 2008 | 07:25 PM
Check the issue and problem section
https://www.rx8club.com/series-i-trouble-shooting-95/hvac-radio-display-cycling-gibberish-147593/
Old Jun 9, 2008 | 11:05 AM
mmats69's Avatar
93.5 octane
the dimming of the lights when you pull both window switches with the windows up is normal. my 8 did it, and all the other previous vehicles i've owned did it. i'm guessing the motor has a high current draw.
I'd take it to the dealer. Sounds like a bad display in both threads.
Old Jun 9, 2008 | 02:54 PM
Jon316G's Avatar
Grasshopper
I'm actually in the same boat as you (not meaning to take over this thread with a different issue). Good to hear I'm not alone.
Jst4fun
Mar 5, 2021 07:16 PM
crimson809
Aug 14, 2016 10:03 PM
GranTouTou
Sep 30, 2015 06:11 AM
Evan Gray
Sep 26, 2015 12:30 PM
