CEL Light
Old Jun 2, 2008 | 10:47 PM
WVBoosted8's Avatar
CEL Light
I have had the CEL light on for some time now and I swapped batteries. All the lights went off and I checked my AP and was getting GREAT gas mileage. Then all of a sudden the light came back on and shot down to 10 mpg average.
Here are the codes I researched
p0301 Front rotor misfire detected
I figure its because I havent changed my coils, wires, or plugs recently. but if that isnt the case I will check leaks/ and or compression
P0108 Baro sensor circuit high input
I didnt find a definite fix for this and didnt know if it was very serious
P2004 APV Stuck open
I found out this is fairly common and takes .7 hours at a dealer to fix.
http://www.finishlineperformance.com...14-07-1777.pdf
But then I got some codes that werent in the forum or in my AP
p2016
p2009
Anyone have any idea what these 2 codes are or have any troubleshooting tips for my previous 3? Thanks alot.
Old Jun 5, 2008 | 09:34 AM
WVBoosted8's Avatar
could anyone give me any input at all on any of these ;/
Old Jun 5, 2008 | 04:01 PM
Go48's Avatar
The last 2 codes do not appear in the RX-8 workshop manual that I have. They could be erroneous codes generated by a partially compatible reader. What did you use to pull the codes?
Old Jun 6, 2008 | 10:45 AM
WVBoosted8's Avatar
Cobbs Accessport
Old Jun 6, 2008 | 11:08 AM
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Jun 6, 2008 | 11:58 AM
WVBoosted8's Avatar
I have already researched on that thread and those 2 cels aren't listed. Also I just wanted any input on how big of a pain it is to get any of those fixed. Thanks
Old Jun 6, 2008 | 08:23 PM
Go48's Avatar
Go the the Engine Diagnostics and Control section of the shop manual and follow the troubleshooting suggestions for those DTC's. If you don't have a copy of the manual, PM me. Troubleshooting these codes can be a complicated process, so if the car is still under warranty, suggest you have the dealer check it out
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Aug 21, 2022 01:29 PM
Emmanyei
Sep 19, 2015 11:12 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
