Hesitation at 7k?
Old Jun 1, 2008 | 07:06 PM
altiain's Avatar
Sparky!
Hesitation at 7k?
Hey guys,
I was Motorsports Ranch today, and I noticed that my car was hesitating momentarily at around 7k rpm under hard acceleration. Nothing huge or enough to upset the car, but enough that I noticed it. I've run several track events this season and never noticed this issue before. Other than that, the car ran fine, even in the 90+ degree heat.
The car is basically stock engine-wise, with nothing but an "Isley special" exhaust system. Running name brand 93 octane fuel, 10w40 dino oil, no premix. Any idea what might be causing the hesitation?
Old Jun 1, 2008 | 07:16 PM
Ports open up around there.
There's a normal dip there.
Get the Access Port from MM. Problem solved.
Old Jun 1, 2008 | 08:15 PM
chiketkd's Avatar
Row faster, I hear banjos
+1 Last intake ports open up at 7,250rpms. I've noticed that slight hestitation as well...seems more pronounced when the a/c is running for some reason.
Old Jun 2, 2008 | 01:10 PM
never had it that I can say
Old Jun 2, 2008 | 02:33 PM
SHOWOFF's Avatar
NOT SEARCHING
Do you notice any difference in the sound coming from the front of the car? Like a gurgle or popping sound? When my car needed new plugs it would misfire and lose power around 7k and make a strange noise.
Old Jun 3, 2008 | 06:41 PM
chiketkd's Avatar
No different sounds or misfires. Car pulls strong to redline - I personally have just felt the slightest pause as the tach sweeps past 7,200rpms.
FWIW, my car has 26K miles and is an '06 (comes from the factory with the revised plugs). Plugs should be changed every 30K miles, so I'll be changing mine anyway this summer before Solo Nats.
Old Jun 16, 2008 | 10:49 PM
manolo's Avatar
manolo
it could be the fuel filter???
Old Jun 16, 2008 | 11:55 PM
SouthFL's Avatar
Fuel pump.
Old Jun 18, 2008 | 01:41 AM
Senna's Avatar
Merchant Of Pace
I doubt it's anything faulty. I noticed it some time ago. Just a slight hesitation at WOT. Seemed to happen right after my shift to 4th if I remember correctly. Didn't notice it at Buttonwillow a couple weekends ago.
Old Sep 9, 2008 | 09:55 AM
chiketkd's Avatar
Swapped in new OE spark plugs this weekend and the slight hesitation at 7K rpms is gone. Car pulls strongly to redline -- especially in the 7-9k rpm range.
Old Sep 15, 2008 | 04:09 PM
Matt RX8's Avatar
^glad you found a fix. I also had a similar issue but it turned out to be the coils. I also swapped out the plugs and plug wires when the coils were done.
Feffman
SE RX-8 Forum
Oct 7, 2015 06:58 AM
Feffman
RX-8 Racing
Sep 30, 2015 05:56 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
Forevermore
Sep 20, 2015 01:04 PM
Redheddude222
Sep 14, 2015 02:55 PM
