How to replace low beam bulbs?
Old May 31, 2008 | 12:49 PM
proficientone's Avatar
04 rx-8
I want to replace my low bean bulbs. I was told I need to access it from the fender walls beside the wheels? When I do this there is some crazy cover on the low-beams. Im a confused noob. How can I replace my bulbs ? Thnx
Old May 31, 2008 | 12:56 PM
Silver06's Avatar
Zoom Zoom....
Hi.
It just so happens that someone else has had this exact same question....
And, they were kind enough to make a DIY, which I found by searching.
Click Here.
Here's another:
Originally Posted by StealthTL
Jack up the front, you need some space to work over the tires. (or take off both front wheels)
Undo the six screw/plug plastic doo-ies that hold the plastic wheel liner in. You need only undo the piece behind the headlight, not the lower bit that covers the oil cooler.
Make sure lights are off .
Large plastic HID bulb cover twists off, anti-clockwise, quarter turn. Rubber seal on it may be tight the first time
Metal clip holds capsule in place, undo both sides.
Replace capsule, being careful not to touch the quartz/glass.
Replace cover, check they work, button it all back up.
S
Search is your friend. Some of the members get quite rude when a question has been asked a million times, and the answer hasn't been searched. The above is a real link to a real thread - however others would post a link to Rick Roll....
Old Jun 6, 2008 | 04:13 PM
Silver06's Avatar
Zoom Zoom....
^reported.
uZu
Dec 30, 2015 12:35 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
Stubbs
Jul 28, 2015 09:23 PM
dbarber
Jul 25, 2015 01:34 PM
