Headlight level problems
Old May 22, 2008 | 09:56 PM
r15's Avatar
r15
I have had some problem with the "auto" leveling of my headlights. I am wondering if other headlights are having similar symptoms.
1. Headlights start at an acceptable level, but around the same time the car has warmed up, the headlights kinda drop a few degrees, say enough to notice.
2. If I start the car, from cold, and the car is parked on uneven ground (engine cold), say in an unpaved lot, the headlights will not stay level and continue to point towards the ground for a few days.
Does anyone have a clear understanding of the level control module? Its not really hard to calibrate the axle sensors, (after inspecting them after reading an earlier post, calibration in American service bulletin to replace sensor harness) but I cannot figure out how to fix this problem.
thanks
Old May 22, 2008 | 10:01 PM
Jon316G's Avatar
Grasshopper
Well... if you read the TSB on this issue, I would take a print-out to the dealer and have them inspect it. I had problems with my auto-leveling headlights and the wire harness was in real bad shape. All work was covered under warranty.
Old May 23, 2008 | 05:30 AM
Go48's Avatar
http://www.finishlineperformance.com...8-07-1729a.pdf
Old May 25, 2008 | 12:04 PM
Jon316G's Avatar
Grasshopper
Spammer reported... now deleted
Old May 30, 2008 | 05:09 PM
r15's Avatar
r15
Yeah the front sensor is shot, dealer is going to replace it. Strange how it would work fine most of the time but every now and then just point the headlights at the ground. Oh and I have yet to see a error light.
Old May 30, 2008 | 05:10 PM
r15's Avatar
r15
Thanks for your help
RevMeHarder
Jun 1, 2026 02:30 PM
Azki23
Jun 27, 2018 03:48 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yankeepicker
Sep 11, 2015 05:42 PM
