Just spilled oil all over the engine bay
Old May 19, 2008 | 10:38 PM
Falken's Avatar
Drop it into 3rd
I misjudged how full the oil container was, and poured without checking. Oil went everywhere, specifically to the right of the inlet when facing the car from the front. I filled about 1/4qt.
I was wondering if oil just floating around in there is going to cause any problems, i.e. clogging something, screwing something electrical, causing the car to spontaneously detonate in a nuclear fireball...anything I should be worried about?
Just in case I need this :
Old May 19, 2008 | 10:39 PM
chancejat's Avatar
Drive it like u stole it!
clean it as best as you can ...the rest will burn off.....
Old May 19, 2008 | 10:45 PM
Use a paper towel to soak it up.
Old May 19, 2008 | 11:09 PM
Falken's Avatar
Drop it into 3rd
Is it going to damage anything is what I'm asking.
Old May 19, 2008 | 11:14 PM
Your Ego!
Old May 19, 2008 | 11:15 PM
Falken's Avatar
Drop it into 3rd
Originally Posted by Razz1
Your Ego!
That was an honest question, I didn't mean it that way. Will it damage anyhting?
Old May 19, 2008 | 11:29 PM
in short, no.
but ur best is to use some electrical safe spray cleaner and spray the crap outa it.
Old May 19, 2008 | 11:53 PM
Soapflake's Avatar
I've spilled oil when filling/changing oil. You'll be fine, just soak up what you can.
Old May 19, 2008 | 11:56 PM
StealthTL's Avatar
Metatron
I'm with nycgps - some non-flammable solvent in the same area is the ticket.
I've had a bottle tumble out of the funnel and do the same dance.....
S
Old May 20, 2008 | 01:36 AM
superglue's Avatar
n00b post whore
That sucks man. Do your best to soak up the oil that you can and use non-flammable solvents (Simple Green?) as the others have mentioned.
Old May 20, 2008 | 07:53 AM
I like that flame suit ... can I have one ?
Old May 20, 2008 | 10:09 AM
Falken's Avatar
Drop it into 3rd
Well I drove it to school today, and it seems like nothing is hurt. I made sure to let it warm before I moved it and didn't go above 4,000 before it was hot.
After that I tried to redline it a few times just to make sure that everything was OK. There was a bit of a smell, I assume that was the oil burning off. Everything else was normal though, it drove like a dream.
It turned out that I also didnt spill as much as I had thought. In all my intelligence I decided to fill the oil at night, in the dark, and misjudged how much missed.
Old May 20, 2008 | 10:15 AM
mysql's Avatar
Doppelgänger
it'll be fine.
But you might want to consider spilling a thicker weight oil on the outside, I hear bad things about 5w20. And try adding some premix too.
Old May 20, 2008 | 11:01 AM
CyberPitz's Avatar
Huge hole is huge
Clean it up as best you can, you should be fine. I think 90% of the people here have spilled some oil before
Old May 20, 2008 | 11:31 AM
Renesis07's Avatar
Vtak just kicked in yo!!
Ive done that a million times. A couple times, on a trip and my low oil light flickers, so Id pull over and attempt to put oil in with no funnel! That was a serious fail.
Old May 20, 2008 | 11:38 AM
CyberPitz's Avatar
Huge hole is huge
I've never used any sort of funnel, so you can imagine where some of my oil goes every fill up.
Old May 20, 2008 | 11:45 AM
Renesis07's Avatar
I hate that smell though. Thats why I get pissed about it.
Old May 20, 2008 | 11:49 AM
EdwardsB's Avatar
Registered RX-8 User
Just plug the bottle with your thumb stick it upside down over the hole and remove your finger...no spills and no need for a funnel.
Old May 20, 2008 | 12:30 PM
secret8gent's Avatar
the enemy in the mirror
< tiny thumbs!
Old May 20, 2008 | 12:42 PM
Falken's Avatar
Drop it into 3rd
Originally Posted by mysql
it'll be fine.
I'm using royal purple 5w30.
BigMikeATL
May 26, 2016 12:31 AM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
RotaryRider
Jul 20, 2015 07:05 AM
