View Full Version : Problems with new ACT CLUTCH AND FLYWHEEL ?
PRX8
05-17-2008, 07:56 AM
I've changed the clutch to Act HD and Act HD pressure plate, ACT prolite flywheel, and feel plenty power.
My only problem is that my first gear is lazy and I can't use my reverse like usual, it feels weird. When using reverse I try not to burn the clutch but a burn smells always comes up, please help.,.. Any help will be great. The mecanic who mounted the clutch said this is normal, I don't think so....it's been over 1,000 miles and the car still does it.
Sometimes the car stays at high rpm's over 1,500 or even 2,000 the normal rpms settings when in neutral and when driving
nycgps
05-17-2008, 09:01 AM
feel plenty power ? ... what a noob
search
GAMBEAN
05-17-2008, 09:44 AM
oh god, not again.
http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__ACT-Solid-4-Pad-Clutch-Disc-03-04-05-06-Mazda-RX8-RX-8_W0QQitemZ320246699988QQadnZCarQ20Q26Q20TruckQ20P artsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?_ trksid=p3756.m20.l1116
PRX8
05-17-2008, 12:05 PM
search
You seem to know a lot about rotary engines with over 6,000 posts in this website, why not throwing in some mecanic advises or maybe reply with technical solutions to what causes these problems,
I'm sure that other people have experienced these issues and will be thankful with your knowledge if any.
kersh4w
05-17-2008, 03:06 PM
your clutch is not going to give you more power. a lighter flywheel will help your acceleration, but it will not give you more power.
our reverse is touchy to begin with.
anyone who buys a HD clutch in our car made a pretty noobish decision. we dont have the power to warrant a heavy duty clutch. hell, we dont even have the power for "stage 1" clutches. so, congrats on that you wasted your money. have fun building up your leg muscles and reducing your driving pleasure.
wassup_nuthin
05-18-2008, 02:17 AM
So if you plan on going f/i but put a hd clutch in your car this is newbish? i have the act hd clutch, therfore i made a newbish move? even w/ my nitrous and supporting mods and soon turbo the 8 wont make enough power for my new clutch to be useful? im confused explain your theory some more please
6dmnbg
05-18-2008, 01:38 PM
Stage 1, Ha, I have an act stage 2 but I also have a ported 20g turbo. Anyways, the transmission went out completly in my car and it was hard to get into reverse right before it happend. Does it feel like the clutch is not fully engaging in first and reverse, this might sound dumb but did you replace the pressure plate when you got the clutch?
PRX8
05-18-2008, 06:19 PM
I have the ACT Prolite flywheel itstalled same day I replaced the cluth
So what is your answer or solution to my problem?
kersh4w
05-18-2008, 09:28 PM
you have quite a lot of power adders (esp. on the way) and you drag race. relax. :lol:
"we dont have the power to warrant..blahblah." obviously this means stock form rx8s. ;)
swoope
05-19-2008, 03:50 AM
i dont think anyone understands your problem...
the clutch works or it doesnt..
the clutch works the same in all gears..
you should worry less about post count figure out how to describe a problem that is likely to happen.. or better yet get a video an make it easy to troubleshoot...
if you are having an issue in 1st and rev, the pp could not be releasing all the way..
many reasons why that could happen..
beers :beer:
nycgps
05-19-2008, 09:09 AM
beers :beer:
well said my friend.
for god's sake why cant ppl press the search button and start searching b4 they post stuff .... I dont understand, is it really that hard to search ?
neXib
05-19-2008, 11:08 AM
I'm going to try to be constructive, let it be noted that I don't have the RX-8 (yet) and I don't have experience with this type of clutch and flywheel. But I have driven some harddriven cars, and what they have in common is that they are far less forgiving than stock clutches, so rather than feel yourself to where you should let out your clutch, you have to press hard on the clutch, and let it out "fast" at the exact point you are supposed to let it out. But that's just my experience with some shoddy older cars with "performance" clutches ;)
When you put it in first, does the gearstick slide easily into first? If so, have you tried letting the clutch out fast/slow, if so what's the difference?
Explain in more detail like they say above. I'm thinking the same as them, first and reverse is the first trouble gears if something is wrong in general, even had that with my Miata. It would be a very good idea to change transmission oil too if you haven't yet. I think you talked about gearing in another thread if I'm not mistaken.
