View Full Version : agency power pulleys
VS8
05-17-2008, 12:30 AM
about how much would it cost to get these installed
Jon316G
05-17-2008, 05:07 AM
Simple to install yourself... don't waste your money paying someone else to install.
Just loosen tension from the drive belt (you'll see that adjusting the alternator's position is what applies/releases tension to the belt). Then remove the four bolts on the crack pulley and be careful not to damage/warp the eccentric shaft positioning plate that is behind it (a plate with "teeth" all around).
The AP pulley comes with a new belt, so just install everything in reverse order.
Jon316G
05-17-2008, 05:15 AM
This should help explain how to apply/release tension to the drive belt:
VS8
05-17-2008, 01:47 PM
is there anything else i need to do
Jon316G
05-17-2008, 01:57 PM
:beer05: :beer: :beerchug: enough said! :)
Just once its installed, start the car and watch the belt and pulley... make sure its not squeaking and the pulley is properly balanced (not wobbly). Do not apply too much tension, but you also don't want it too loose.
dannobre
05-17-2008, 01:58 PM
You will likely have a difficult time getting the alternator pulley nut off...unless you have an impact gun....other than that it is straight forward
mysql
05-17-2008, 02:01 PM
walmart sells a cheap impact gun for around $25. Worked fine for me.
VS8
05-17-2008, 08:59 PM
but say i am not able to do this about how much would it cost me
dannobre
05-17-2008, 09:31 PM
Probably get away with 1-1.5 hrs...so $100-120
VS8
05-17-2008, 10:48 PM
do you have any more pics i can use to install the pulleys
Jon316G
05-18-2008, 10:05 AM
staticlag wrote-up a DIY that should be easy for you to follow:
http://www.rx8club.com/showpost.php?p=1375509&postcount=34
LiL BenNy
05-19-2008, 10:56 PM
easy, trust me i even did my own...as for the impact wrench its not needed u just need a long breaker bar or something togive u leverage... hell i didnt wnana pay the 30 bucks for one and just used one of my old alluminum hockey shafts... worked like a charm!
