NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Local MD Turbo Owners - Help Please
Old May 16, 2008 | 05:47 AM
ldc6's Avatar
I have the Mazdamaniac upgrade to the Greddy kit with the Cobb Access Port and I've had nothing but trouble getting this thing running properly. Does anyone have recommendations for a local (Columbia, Baltimore, etc...) speed shop or someplace I can take it to that has experience with turbo'd RX-8s for some help figuring out what's wrong with it? Or if you are a local owner that either has the same setup or knows a lot about this stuff and can help can you let me know. Appreciate it!
Old May 16, 2008 | 09:25 AM
flyboi1121's Avatar
werD?
Sorry to hear about that...what kind of problems are u experiencing? there should be threads that will most likely explain your troubles.
Old May 16, 2008 | 10:01 AM
Im_DANomite's Avatar
I love GOOOLD
i have the greddy kit with cobb ap. maybe i can help out.
Old May 16, 2008 | 10:10 AM
mysql's Avatar
Doppelgänger
intake/maf is most likely the problem. The greddy intake isn't designed for properly airflow across the maf sensor. So it's going to bog down due to the pcm adding too much fuel.
Old May 16, 2008 | 12:43 PM
ldc6's Avatar
well, let's see. We have everything installed. Been driving the car but haven't been able to get on it much because when we log our AFRs are peaking too high under boost. We sent a log to Mazdamaniac and finally got a new map for the AP and loaded that and now it's even worse, higher AFRs. When asked MM said that he made the map super rich and we should be seeing 9s, not 14s.
I have no idea what the problem might be but I'm scared I'm going to blow the engine testing it to keep doing these logs
We were thinking maybe we put the injectors in the wrong place but we're 99.9% sure that's not it (but we're going to check again).
Here are our logs just to show what we are seeing. First one is from a few days ago which we sent to MM, the 2nd is after he sent back the new "richer" map.
Some more details on what I have...MM's kit to the Greddy Turbo, Cobb AP, manual boost controller, Innovate LC1 WB and Innovate OT1 to log.
Do you think the intake/maf would cause this type of problem? We plot MAF on the chart below..does that reveal anything?
Purple is AFR (from the LC-1), black is RPM, green is throttle, and red is MAF
Attached Thumbnails Local MD Turbo Owners - Help Please-051308_3log_lc_edited.jpg   Local MD Turbo Owners - Help Please-051508_2log_lc_edited.jpg
Old May 16, 2008 | 01:10 PM
MazdaManiac's Avatar
Your MAF reading in boost look perfect.
Adding fuel to the calibration actually took away fuel (I put in so much fuel that it should be rich-misfiring), so my first inclination is that you got the P1s and P2s mixed up or their connectors misplaced.
Next possibility is the fuel pump or the pump speed resistor.
You should also verify the proper function of the SSV, VDI and APV.
Seeing as how there are several people running around with the exact same setup as you that are not having this problem, it would appear that there is an issue in the setup/operation of the fuel delivery system.
Old May 18, 2008 | 02:37 PM
ldc6's Avatar
Looking in the shop manual it looks like the APV might be hard to test. Any tips there? I'd hate to have to pull off the entire intake manifold to check that. Looks like we can check the SSV and VDI a little more easily (because they are visible) by doing some RPM checks, correct?
How can we test the fuel pump operation?
Old May 18, 2008 | 08:56 PM
kersh4w's Avatar
Hit & Run Magnet
http://www.pfsupercars.com/
if you want a local professional to work on it. they do a lot of turbo rotary work.
Old May 18, 2008 | 11:42 PM
You can test them all by free-revving through the full RPM band while parked.
The APV has a cap over the drive armature that you can remove and watch the thing turning.
The PCM also runs all of the valves ever certain number of power-downs.
I think the number is in the FSM.
You can put it in test mode by shorting the relays.
That is also in the FSM.
Yeah, Ray is a good guy. I don't know how much RX-8 stuff he does, but he knows what he is doing.
He's in Frederick, so it isn't too far from Laurel.
Did you try the last calibration I sent on Friday?
Old May 19, 2008 | 08:50 AM
ldc6's Avatar
Jeff - Thanks for the info. We'll do some more reading in the shop manual and see what we can find. We didn't try the map yet because we're pretty much certain that we have some other problem that the map won't address.
And, kersh4w, thanks for the shop name... we'll look into that if we can't make any headway.
Old May 19, 2008 | 10:59 AM
Try it anyway. I am experimenting with injector scaling on your calibration and it will help pinpoint if something is switched.
Old May 19, 2008 | 12:00 PM
ldc6's Avatar
ok, we'll load it and send you the log in the next day or so. thx.
Old May 26, 2008 | 06:55 PM
kenkamm's Avatar
Jeff,
Any chance you could elaborate on where this cap is? Is it on the connector end, or is it on the manifold side? I see a gray cap that looks like it would come off, but it looks like it's covering a very small port or something, so my guess is that's not what you're talking about.
I was able to verify the correct operation of the SSV and VDI, but the APV isn't so easy.
Also, I was thinking of cutting the fuel line near the upper intake manifold and inserting a brass t-fitting in order to connect a fuel pressure gauge. Is there anything wrong with doing that?
Thanks,
Ken
Old May 26, 2008 | 07:12 PM
Rotr8's Avatar
whines all the way home
PFS they're the best.... I've been there, top notch shop, lots of Rotary experience,,,
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
Azki23
Jun 27, 2018 03:48 PM
DubbsLuvs8s
Sep 8, 2015 06:51 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
