new 8 owner wondering what oil/fuel to use
Old May 11, 2008 | 09:58 AM
13bturbofc's Avatar
400whp RX-7+05 RX-8=BROKE
so i just bought my first rx8 yesterday its an 05 with 18k miles on it. i own two 2nd gen rx7s and i know alot about rotaries but not much about the rennisis so im wondering what fuel is best to run in it, i know on the N/A 13b second gens they say they run better on low grade but of course the turbos require high test, so whats best for the rennisis? and also what brand/ type of oil is best? the dealer offered a 10k mile warrenty if i get oil changes every 4k miles and use quaker state oil. ive never used that brand oil cause ive heard bad things in the past about it but i have a good freind that owns a quick lube shop that im sure will just write on the reciept that i got quaker state when i really didnt lol. so let me know what you think. thanks
Old May 11, 2008 | 10:56 AM
Falken's Avatar
Drop it into 3rd
5w20.
Prepare to be flamed.
Old May 11, 2008 | 11:27 AM
To be named later's Avatar
Now with 25% more fluff..
Old May 11, 2008 | 11:50 AM
invasion08's Avatar
I use castrol gtx 5w20 and 93 octane fuel
Old May 11, 2008 | 11:53 AM
dothackRAVE's Avatar
<3 Rotary
All RX-8s come with a 5 year or 50,000 mile warranty. Your dealer's ripping you off.
I bought the same year RX-8 as you used, with 20,000 miles, and my warranty supposedly expires in 2010!
Personally, I use Castrol GTX 5w20 NON-SYNTHETIC for my car. Don't ******* touch synthetic unless you want to get AIDS (rule applies to rotary cars only). Oil's clean, and the car seems happy. I'm won't be changing to another brand anytime soon...
EDIT: Also, for fuel, I use 93 octane, although the RX-8 can happily take anything 87 and a above.
Old May 11, 2008 | 02:30 PM
kevinD1226's Avatar
check out idemitsu oil, specifically designed for rotary engines. a bit expensive but owell, use 93 octane gas, for someone who is supposevely knowlegable about rx7s u sure seem pretty clueless about rotarys'... some believe synthetic oil is bad for the rotary cause it doesnt burn as cleanly as regular oil, some are runing synthetic with no problem, i change my oil every 3k miles so i dont find a need to run synthetic. u will not get a straight answer on oil on this site so the best u can do is read some then make ur own decision, since i have a feelin ull be askin what the best intake/exhausts/ so on just put it this way there all noise makers thats it!
Old May 11, 2008 | 02:54 PM
StealthTL's Avatar
Metatron
low octane is ok unless turbo'ed.
use whatever oil you 'feel' good about - QS oil is fine, it's all made by SOPUS anyway......
quit stressing and drive!
S
Old May 11, 2008 | 04:46 PM
13bturbofc's Avatar
ok i should have said i know alot about the 13bt motor but i dont know **** about a renesis. ive built my own motors in the past and i currently have a 87 tII with 405 rwhp, so yes i know alot about rotaries but not rx8's. i do know not to run synthetics because of the metering pump and carbon deposits. and its a proven fact that non turbo 13b's run better on 87 octane so i was just questioning wheather or not the same was true for the renesis.
tallestmexican
May 1, 2018 07:22 AM
nowakm99
Oct 9, 2015 07:10 AM
Randolph Alvarez
Sep 14, 2015 04:25 AM
yankeepicker
Sep 11, 2015 05:42 PM
Tsurugi
Sep 7, 2015 08:27 PM
