MT-90 + MTL for tranny?
Old May 6, 2008 | 03:44 PM
Gdawg522's Avatar
Rotary Addict
Hi everyone,
I'm getting ready to swap my tranny and diff oils this weekend. My only concern was some people complaining about the notchiness after changing to MT-90. I know there are some users that use MTL for the tranny. Do you think there would be any benefit by getting a quart of each and mixing them together before I put them in. As long as they mix well together I don't any problem with giving it a shot. Thanks for your help.
Old May 6, 2008 | 04:41 PM
I feel fine using MT90, I dunno what other ppl mean by *notchiness*, but I am ok with it. Oh, I came from the RP Maxgear boat.
Old May 6, 2008 | 04:54 PM
StealthTL's Avatar
Metatron
The 90 weight IS the Mazda spec - I use the mix because I regularly drive around in minus 20* weather.
S
Old May 6, 2008 | 05:00 PM
Gdawg522's Avatar
Rotary Addict
ok well I drive my car in weather no colder than 20 degrees Fahrenheit. Right now the temperature is around 70 degrees. So mixing about 3/4 Mt-90 and then 1/4 MTL would that have any benifit? I might just give it a try. A little MTL shouldn't cause any problems in high temps do you think?
Old May 6, 2008 | 05:06 PM
if u never drive cold, I guess u should stay with the stock weight.
Old May 7, 2008 | 07:19 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
MTL is probably too light for you
Old May 11, 2008 | 07:18 PM
Gdawg522's Avatar
Rotary Addict
Ok well I just got done changing my my fluids over to redline. When I started the car to back it off the ramps, I began to smell a very rank smell from the car. I think it is the exhaust but I'm not sure. Is this smell normal after changing transmission and differential fluids?
Old May 11, 2008 | 07:26 PM
StealthTL's Avatar
Metatron
Yes, they stink, especially the diff oil. It will pass.
S
theblinkof
Oct 4, 2023 05:24 PM
JAYDOH
Sep 24, 2015 01:54 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
