View Full Version : engine light just came on!!! shhaaatt!!!
felk420 05-05-2008, 07:55 PM man i took off today to go the pool at my friends place(about 2 miles away) never had any problem with the 8 besides sum flooding but i parked it there for about 2 hours then i left to go to the mall (about 10 miles away) n half way there my engine light came on. i stopped right away n checked fluids n saw that my oil was a lil low so i added sum 5w20hough that was it when i took off again my light was still on, i checked the oil compartment and it was a lil smoke but nothing crazy just like a puff of a cigarret, with nothing more that i could do i drove home with ease and i could tell that my engine was running really strange is almost like rpms were going up but not much speed was coming out, i dunno man really freakd out by this shyt so if there is sum1 who can help me id really appreciated...by the wasy my car is a 04 and it has 33,000 miles on it i do everything by the book high rev sutoffs good warm ups and i change my oil every 1,200 miles.....appreciate what you drive and i hope is a 8
felk420 05-05-2008, 07:56 PM o yeah by the way when i would start my car back up the light was still on and it would take a lil longer to start
tubingchamp 05-05-2008, 08:02 PM Does it have a Mazdaspeed CAI? (cold air intake)
DarkBrew 05-05-2008, 08:07 PM You're right in (the early part of) the zone for coil failure.
Have you changed plugs, coils and plug wires yet?
crafted_soul 05-05-2008, 08:29 PM You still have warranty, right? since its only at 33,000. My car also is 04 and has 39500 miles on it. My basic warranty runs til 03/09 or 50,000 whichever comes first. So if you still have warranty, don't even bother messing with the car. Just take it to the maz service center and let them run diagnostic. That's what I would do.
felk420 05-05-2008, 09:18 PM no i have kn v2 typhoon....n no i havent change any of those things, i just bought my car about 9 months ago so i didnt think i need it...and will the warrante still cover since i am the secong owner of the 8? thank you by the way
felk420 05-05-2008, 09:19 PM i been reading about the ecu, cel, kan, resets and i really have no ideah wat the kshit is so can any1 explain....?
felk420 05-05-2008, 09:20 PM darkbrew---how much can that run me out of my pocket?
DarkBrew 05-05-2008, 09:49 PM darkbrew---how much can that run me out of my pocket?
Coils are about $100 for four.
Plugs are about $110 for four
Get those at finishlineperformance.com
Plug wires are around $95 from RacingBeat
You can install yourself or find a good shop
felk420 05-05-2008, 09:54 PM since the cel just came on 2day how long do i have to change them cause i cant buy em right now due to the lack of green paper in the bank or my wallet :( poopy
DarkBrew 05-05-2008, 10:03 PM Well you can try the plugs first and spread out the spending.
First things you can do.
Check if any of the plug wires have come loose.
Pull out the plugs for inspection; take a picture of the plugs and post it here.
You can can have the plug wires tested
felk420 05-05-2008, 10:07 PM alright ill do that 2morrow after finals and ill post em on here.....what are your opinions on the ecu reset and ....short memori shyt that i have no what is called...thanx for your help
DarkBrew 05-05-2008, 10:16 PM You'll be disconnecting the battery as the first step of working on the car.
By the time you're done the ECU will be reset.
The E-shaft sensor is another story which I don't remember
Jon316G 05-05-2008, 11:26 PM Its hard to start anywhere without knowing the code that generated the CEL. Don't worry about plugs, wires, coils or anything until you find out what caused it. The CEL could be the rear O2 sensor which is a cat issue. Take the car up to Autozone and have them pull the code and post it back here. The code will start with a P followed by a couple numbers (ex: P0301 is for cylinder #1 misfire).
But like crafted_soul said, the car is under warranty, so you could just let them deal with it.
Jon316G 05-05-2008, 11:29 PM Also, if you take it up to Autozone and get the code, you can reset the KAM (which contain the sensor profiles) by:
1) Turn the key to on (but don't start the car)
2) Depress the brake pedal rapidly ~20 times until the oil pressure gauge sweeps to halfway and back again.
This will clear the CEL and let the car relearn it's trim
DarkBrew 05-05-2008, 11:35 PM Jon316G is correct and I'm over tired. Pull the code as step 1.
truemagellen 05-07-2008, 06:33 AM Our ignition will be out soon if you can wait that long for a serious upgrade...no more replacing stock coils :D
delta420 05-07-2008, 01:02 PM yo this is felk420 man i got banned for saying sum shyt on my felk420 name but yeah ima go 2 advance today and get it checked out....i just dont get it man it was running perfect and it seems like it still is running perfect but the cel is still shownnnnn G4YYYYYYYYY!!!!!!!.....ill get back to you guys if i dont get banned again....lol thanx tho rx8 is a passion not a ride
crafted_soul 05-07-2008, 02:52 PM no i have kn v2 typhoon....n no i havent change any of those things, i just bought my car about 9 months ago so i didnt think i need it...and will the warrante still cover since i am the secong owner of the 8? thank you by the way
I'm the second owner too. I bought my 2004 used. Most car warranties are transferrable. You can just take out the kn v2 typhoon and put the OEM one back on, and then take it back to the dealer. I mean that is if you still have the OEM one. If you don't, well you can still ask them... you have nothing to lose. Asking doesn't cost you a thing. :)
I would do that first before I start spending my own money...
delta420 05-16-2008, 07:32 PM yo man i just found out that the cel was my gas tank wasnt holdng enough pressure and it was making the cel appear.....is this bad? i heard is not 2 bad.....what do u guys think?
nycgps 05-16-2008, 11:43 PM http://www.rx8club.com/attachment.php?attachmentid=120779&stc=1&d=1210995767
http://www.rx8club.com/attachment.php?attachmentid=120780&stc=1&d=1210995792
This whole thread failed.
If you search you will find the answer.
If the CEL blinks it means your intake is dirty or your getting bad air into your engine. Look for escapes and unwanted dirt thru the entire system.
If CEL it stays on then "good luck" could me many things, go to Pepboys, Auto Zone or Western Auto so they can read the error code if you don't have a CEL module reader, these run for almost $250 or even $325 for our cars, this is the first thing you buy when your adding mods to any car, it will save you money and time. Jejjee but then I could be wrong because I'm a neewby just like you.....haahaha
If the CEL blinks it means your intake is dirty or your getting bad air into your engine. Look for escapes and unwanted dirt thru the entire system. Also could be you spark plugs blown, eventually with a CEL it will tell you which one is bad. Duuuhhh...but again sorry you didn't know that.
If CEL it stays on then "good luck" pretty much ur f+#*ed ,could me many things, go to Pepboys, Auto Zone or Western Auto so they can read the error code if you don't have a CEL module reader, these run for almost $250 or even $325 for our cars, this is the first thing you buy when your adding modscar, it will save you money and time. Jejjee but then I could be wrong because I'm a neewby just like you.....haahaha
swoope 05-19-2008, 04:35 AM If you search you will find the answer.
one. you dont have a clue about what you are talking about.. everything above is not correct..
second. you quoted a big photo.
third. you did it twice.
please, if you dont know what you are talking about. dont give advice!! it is not dealers choice here.
you really dont know how to describe a question. or dont know what your are talking about again.
i have the link if you dont recall what i am talking about..
you are running into the king of fail light.
beers :beer:
felk420 05-20-2008, 07:18 PM swoope knows what hes talking sbout like i said it was a cel....when i took it in to get it checked they told me it was the engine fuel line wasent holding enough pressure....nothing to bad....i erased it n the car runs like a new puppy....thanks swoope n prx8 take swoopes advise....."dont give advice if you have no clue what a rotary engine is"
