View Full Version : Trying to separate the stock catback exhaust pipe from the canisters
poweredbyplaav
05-04-2008, 10:04 PM
i recently installed the sp2 exhaust, and im trying to fit the stock catback in my storage. im trying to separate the catback pipe from the cannisters, but no luck. it seems as though they are held together by a U shaped metal screw. i was able to take the U shaped screw off, but the pipes are still connected.
anyone succeed in separating this?
Astral
05-05-2008, 02:32 AM
No, and I had only 5K on the exhaust. Had to saw it off. It rusts on real quick.
Mazmart
05-05-2008, 07:15 PM
It's crimped after they're joined. They aren't meant to come apart unfortunately.
Paul.
Snakebite202
05-05-2008, 07:44 PM
Metal saw and pair of gogles - works wonders.
yale02
05-05-2008, 07:46 PM
I just recently did it by spraying WD40 into the joint and having a friend help twist and pull it off. It was on really tight but it did eventually separate.
Good luck!
poweredbyplaav
05-06-2008, 01:55 AM
nice. ill give it a shot with a lotta wd40!
TeamRX8
05-06-2008, 10:38 PM
Mazda specifically says never take it apart because it will never seal again per Mazmart's comments, if you do then a new pipe is required
lilring
05-06-2008, 11:27 PM
i had to do the same thing when i installed my borla... i just took a plasma cutter and cut that off... which is always fun to do.
poweredbyplaav
05-07-2008, 02:14 AM
well cutting it defeats the purpose of separating them, since the main reason why im trying to fit it in my storage is to be able to use one day if i ever needed to.
turborx8
05-07-2008, 02:29 AM
Any shop can weld them back together.
lilring
05-07-2008, 10:38 AM
anyone with a welder will do it for you... it doesnt take long at all to do and wont cost much either
