View Full Version : Hesitation while driving.....
cruzdreamer
11-12-2003, 04:28 PM
I experienced a strong hesitation as I was driving......like it was gonna die on me....it took a few seconds and then the car picked up and went. I have the automatic and I had just left the garage and I am thinking maybe the car needed to warm up......temps were decent out. Also, it seems when I use the manual shift mode the car is smoother as it shifts then in regular drive mode. Anyone Have any thoughts about this stuff? Thanks.
Jhouse
11-12-2003, 04:58 PM
definatly let it warm up. my dakota does this if it is not warmed up pretty much to full temp. it is an automatic. granted it is not a rx8 but it does the exact same thing when it is not warmed up unless i just slam the gas petal to the floor.
Gyro
11-12-2003, 05:05 PM
You might be experiencing the cold program rev limiter.
When the engine has not been warmed up the rev limiter would be around 6000 I believe. If you reached that RPM, you would defiately feel a strong hesitation. A few Forum member have posted very similar findings. This is for A/T ot M/T cars alike.
cruzdreamer
11-12-2003, 06:28 PM
I will tell you my husband is not impressed with the car's power. I like it fine, although I agree with him that it drives way better in manual shift mode. It's guzzling gas....will have to figure out what MPG I am getting. I guess I will let her warm up a bit before I drive.......not used to the different kind of engine. I hope MPG improves. Thanks for the input gang!
