Compression numbers in relation to dyno numbers
Old Apr 27, 2008 | 01:49 PM
bryanl's Avatar
Hey guys
Got the car dyno'd today, after a few weeks ago getting it compression tested by go48. It got 175, which is a little low for what I thought it'd be getting. It is stock except for a tanabe exhaust.
The fuse was not pulled, he said he turned off the dsc though.
When I did get back in it after the pulls, traction light and the abs light were on. Had to disconnect battery and the traction light was still there, car wouldn't hold idle either(stalled). Finally all the **** cleared out.
Either way, here are the numbers. Seems pretty low so I wanted to get your guys thoughts. Looking at the sheet, doesn't seem like he went up to 9k. It was a dynojet
Attached Thumbnails Compression numbers in relation to dyno numbers-compressionresults.jpg   Compression numbers in relation to dyno numbers-dyno1.jpg   Compression numbers in relation to dyno numbers-dyno2.jpg   Compression numbers in relation to dyno numbers-dyno3.jpg   Compression numbers in relation to dyno numbers-dyno4.jpg
Old Apr 27, 2008 | 05:59 PM
kersh4w's Avatar
Hit & Run Magnet
a bit low, but not unheard of.
Old Apr 27, 2008 | 06:28 PM
TrochoidMagic's Avatar
is adjusting valve lash
wow! a tanabe exhaust will get you 8whp?
mine is stock! a k&n drop-in isn't exactly a intake... and RB duct, well.....
but '07 with 167~whp iirc. but its mustang dyno and i don't think he did it right as i don't haave a graph with a curve.
Old Apr 27, 2008 | 06:45 PM
kevinD1226's Avatar
ouch, im gettin mine dynoed this upcoming week, with my mods im hoping anywhere between 180-195 whp... not even sure what a stock one puts but thoose are the #s im hoping for atleast..
Old Apr 27, 2008 | 10:33 PM
kersh4w's Avatar
Hit & Run Magnet
are you driving an auto trochoid?
i havent dyno'd my car. but im pretty sure im putting down more than 167whp. we have seen rx8s run 14.4s in the 1/4. you need more hp than 170whp to hit that in a car that weights 3180 with driver.
gwailo
May 14, 2024 06:57 AM
05rx8mazda
Nov 28, 2015 09:42 AM
Trinads
Sep 10, 2015 01:05 PM
Tsurugi
Sep 7, 2015 08:27 PM
