MW RX-8 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS,
Good muffler shop in chicago western burbs?
Old Apr 27, 2008 | 02:43 AM
mdw1000's Avatar
I'll snap his neck.
Looking for a shop that will cut the tips off my Mazdaspeed exhaust and weld on new stainless steel tips (non-Mazdaspeed tips). I've got quite a bit of surface rust on the tips of this exhaust.
Old Apr 27, 2008 | 09:08 AM
amstarvid's Avatar
ZM ZM X 8
I have rust on the tips of my borla as well...sucks, doesn't it.
Old Apr 27, 2008 | 12:24 PM
mdw1000's Avatar
I'll snap his neck.
Yeah, I would probably just try to ignore it, but with the parade coming up, if I can get new tips welded on for a reasonable price, I might just go ahead and do it.
I found these tips online last night that are supposed to resist discoloration. Haven't measured yet to see if they fit, but if they do the price seems fairly reasonable.
http://assureda.startlogic.com/ACSL25X6TIP.html
Old Apr 27, 2008 | 08:30 PM
amstarvid's Avatar
ZM ZM X 8
So this won't rust?
Old Apr 27, 2008 | 08:38 PM
lilring's Avatar
Finally a MT
hey. i have some good poilsh that really helps it.. ill get the name of it for you tomarrow. is your rust like little black spots on it the tips?
Old Apr 28, 2008 | 10:11 AM
amstarvid's Avatar
ZM ZM X 8
I've got some polish that works pretty good - don't remember the name of it - the polish is light blue - but the spots around the tips (which I just started seeing more this winter) appear to be rust spots - I'll certainly try a different polish tho
Old Apr 28, 2008 | 06:24 PM
mdw1000's Avatar
I'll snap his neck.
No, it's actual rust this time.
I was just reading some threads on a caddy forum after doing some searching. Sounds like some of them have had good luck with a "00" steel wool and window cleaner. Might give that a try, at least on a small spot. The neverdull doesn't do anything for this stuff.
Old Apr 28, 2008 | 09:31 PM
amstarvid's Avatar
ZM ZM X 8
let me know if that works...
Old Apr 28, 2008 | 10:33 PM
lilring's Avatar
Finally a MT
well if that stuff doesnt work i know of a place in rockford that will do it. they will do just about anything with exhaust..
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
Jvswan
28
Jul 23, 2015 09:02 AM
