RX8YA
04-26-2008, 07:12 PM
Hello all I just recently purchased a Greddy SP2 catback exhaust with no hardware and wondering what I will need to complete the install can anyone help me. I believe I will need a 3" doughnut gasket, possible new bolts for the midpipe to catback pipe. Now this is where I am slightly confused. The connection of the muffler to the pip that comes as part of the catback system this is where I will need that 3" doughnut correct but in terms of nuts and bolts what should I use here? If anyone could help me with my list for my trip to autozone that would be greatly appreciated. My car is lowered and it seems to be a pain to get jacks under the car and my jackplate is rather small to fit on the trailing are so I tried the plywood board but I dont have enough clearance would using ramps do the trick?
Jon316G
04-26-2008, 07:58 PM
I have an Agency Power catback... but the installation is the same.
I just reused the gasket and bolts... everything worked fine. If this is the first time taking the catback off... I don't see any problem with reusing it.
Jon316G
04-26-2008, 08:04 PM
oops... I just reread your post. I didn't require any additional purchases connecting the two catback items together... what I referred to was the connection to the cat pipe. But you might want to wait and hear from someone here who actually has installed the Greddy SP2.
expo1
04-26-2008, 08:14 PM
The parts you don't have is the gasket in the photo & two nuts, washers & bolts. That goes in-between the mufflers & pipe. The bolts can be found anyplace and the gasket is also something you can find at an auto parts store.
RX8YA
04-26-2008, 08:23 PM
My hero off to the auto parts store. so 2.5 inch gasket and some sort of nuts and bolts from autoparts place.
expo1
04-26-2008, 08:32 PM
My hero off to the auto parts store. so 2.5 inch gasket and some sort of nuts and bolts from autoparts place. I would get SS hardware. My 1st SP2 had 70,000 miles on it when I had to remove it and the hardware Greddy included was rusted. If you have problems finding a gasket I have an extra one I can send you. The thread below might also be of help.
http://www.rx8club.com/showthread.php?t=73142
