Help Needed
Old Apr 25, 2008 | 12:57 PM
behram's Avatar
Help Needed
my rx8 coolant level light comes on tell me which coolant to use and one question more on the cap it is written coolant only so u dont have to put water or what
Old Apr 25, 2008 | 01:31 PM
Silver06's Avatar
Zoom Zoom....
It would be REALLY handy if you at least told us what year RX you have. This is because some of the cars use a special type of coolant which CANNOT be mixed with regular stuff.
So, given limited information....
If your pressure cap says "FL 22" on it, then you should can only use FL22 special coolant. I think it comes already pre-mixed.
If your pressure cap doesn't say to use the FL22, then a 50/50 mix of regular coolant and distilled water would be good.
BTW, don't open the pressure cap when the engine is hot.
Also, if you have to add coolant, you should make an appointment for a pressure test to see where the coolant is going. If you bought the car used, now would probably be a good time for a flush/refill - and a check of your hoses.
ps. Not hatin' on ya, but - - - Edit your title to be more descriptive - -
Old Apr 25, 2008 | 01:54 PM
wrong wrong wrong.
There is NOTHING SPECIAL about FL22 other than its a regular extended coolant in 55/45 mix (coolant/antifreeze), which is pretty BAD for transfering heat, but it has a very very long life.
Mazda do this because cooling system is the most neglected part in the whole car. People remember to check for oils and stuff(lots of ppl still never check their oil tho), but never pay attention to the cooling system.
so in short, you can just buy some Regular Anti-freeze (the Green stuff) and mix it in. it will work just fine.
but before you add any coolant, you might want to check and make sure that you're actually *low* on coolant, cuz sometimes it might be just a bad coolant sensor/connector.
Old Apr 25, 2008 | 03:20 PM
Silver06's Avatar
Zoom Zoom....
nycgps. I agree to a point. The Manual does say that if you put in regular coolant: "the engine coolant must be replaced earlier than the specified replacement interval..." I'm just trying to give the O/P the Mazda Recommended advice, in case he is still under warranty.
Not tryin' to start a 5/20 vs 5/30 fight here, lol. ;-)
Old Apr 25, 2008 | 03:31 PM
behram's Avatar
i live in a country where temperature is around 38 to 45 celsius and why should i add anti freeze and plz tell me which coolant to use and should i put water in the radiator or not
seb16
Sep 15, 2016 12:20 PM
GracefulShanks
Aug 18, 2015 11:40 AM
TheRedRotor
Aug 9, 2015 11:23 PM
SayDfuse
Aug 3, 2015 10:41 PM
