View Full Version : Where do you tap the oil line for the input oil for the turbo?
FloppinNachos
04-25-2008, 07:57 AM
I've been searching for this kinda on and off for a few weeks. I've never installed a turbo kit, I've researched a lot and the one little thing that I haven't figure out is where to tap the oil for the turbo? Can you use one of those plate adapters that fit between the oil filter and the oil filter mount on the engine?
mysql
04-25-2008, 08:08 AM
turbo kit usually comes with a T and a braided stainless steel line.
then you either get the greddy oil pan for the return line, tap a new hole in your oem pan, or route the return line into your oil drain line.
the last option is annoying cause you have to disconnect the oil return anytime you change the oil. I like the greddy option best cause you can use the fumato valve with it.
imrtommy
04-25-2008, 11:59 AM
you mean oil feed line?
rotarygod
04-25-2008, 12:42 PM
Yes that works fine.
tdiddy
04-25-2008, 12:56 PM
I started with a sandwich plate for my oil feed line but I changed it to a "T" that is mounted to the oil sending unit hole. It will work either way.
FloppinNachos
04-25-2008, 04:23 PM
where does the T go though? The line that comes from the oil cooler?
