Tapping felt in foot through clutch pedal.
Old Apr 24, 2008 | 06:01 PM
Docj78's Avatar
Perhaps this is normal engine/tranny vibrations and/or I'm being paranoid, but with my clutch pedal completely depressed, I can feel a fast tapping or pulsing in my foot.
This of course only seems to happen at a stand still, whether or not the car is in gear. I can make the frequency increase to the point of "disappearance" by throttling up the RPM's, and often after the R's drop back down, it goes away for a second.
What could this be other than "normal" drivetrain vibration? Am I being a paranoid less-than-one-week owner?
Old Apr 24, 2008 | 06:11 PM
Spinning Sushi's Avatar
I <3 Sushi
If you're talking about the throw out bearing that makes that scraping (Goes away when clutch pedal is pressed) sound then it's normal.
Old Apr 24, 2008 | 06:17 PM
Docj78's Avatar
Nope. Not the throwout bearing sound. I've had that on several other manuals as well.
This is a physically felt, albeit subtle, tapping or pulsing--With the clutch pedal pushed in.
Old Apr 24, 2008 | 06:40 PM
Go48's Avatar
Do you get a squeak when you depress the clutch pedal? There have been problems with failed spot welds in the clutch pedal support bracket. Perhaps you should look into that as a possible cause of your problem. Do a search of the forum and read some of the posts.
Here's a link to the main thread:
https://www.rx8club.com/showthread.p...clutch+bracket
Old Apr 24, 2008 | 08:13 PM
Docj78's Avatar
Yea, my pedal squeaks and I have printed the TSB for it. Don't know if that is related to the "pulsing" or not--I doubt it b/c it's unquestionably dependent on engine rpm. Again, when I rev the car, the frequency increases to the point that the pulse becomes linear and "solid".
About the squeaky clutch pedal though, I has my car refalshed on MOnday and mentioned the squeak to the service advisor. He just said "Meh, spray some silicone lube up there." PITIFUL.
Old Apr 25, 2008 | 08:08 AM
Go48's Avatar
Get under the dash with a flashlight and closely check out all the spot welds around the clutch bracket.
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
