Lost Pinch Weld Adapter for floor jack, how to jack each corner individually?
Old Apr 24, 2008 | 04:09 PM
Daemos's Avatar
So I lost the pinch weld adapter that I would normally use for my floor jack, I would buy a new one but it takes 2-3 weeks for it to come in and I'm going in a road trip before then.
I've been spoiled by this thing as I've used the factory scissor jack points to jack up the car. I know you can lift up the rear ends and the front ends individually using the rear diff and the front jack point behind the bumper under tray.
But I want to jack each corner up individually using my floor jack, where would I jack up the car so I won't damage the underbody?
Old Apr 24, 2008 | 05:34 PM
Go48's Avatar
Same place. Take a 2x4, cut a small block, about 3" square, and saw/cut a slot in it across the grain about 3/8" deep by 1/2" wide. Put the block on the floor jack pad with the slot up and use the recommended jacking points at each "corner" of the car.
Old Apr 24, 2008 | 06:41 PM
Daemos's Avatar
Holy that's ingenious!
Old Apr 24, 2008 | 06:49 PM
Go48's Avatar
Yeah, you can make 4 of them and use jackstands at all four corners when you need to do major work on the car.
Old Apr 24, 2008 | 08:18 PM
at the same spots; it's a $25k car that loses 40% of it's value immediately, not a $1Million show car ...
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
XianUnix
Sep 29, 2015 03:48 PM
Digitz0070
Sep 25, 2015 10:58 PM
