GrRx8MaZdA
04-24-2008, 09:52 AM
Hi.
I have a centered single exhaust with 3" pipe and right now i have the stock cat on..
Soon i m installing my mazsport and i m going for a catless race pipe 3"..
The sound will be freakin loud so i was thinking of a fully controlled exhaust tone valve-just for cops and night hours in neighborhoods..
So.I checked with apexi but i dont know which on i dimensions and i dont know if there are any cons and also where do you install this thing in the race pipe or in the exhaust pipe???
http://www.apexi-usa.com/product_exhaust_detail.asp?id=251&pageNum=1
Thanks in order
staticlag
04-24-2008, 10:08 AM
It would probably fit best at the bend area in the midepipe, you could make a turndown that went straight. and the rest of the exhaust that went left. But really though if you are going turbo you should just do wastegate to atmosphere.
Hi.
Thanks in order
GrRx8MaZdA
04-24-2008, 10:15 AM
The mazsport kit has a tial wastegate..So i have one.But will this throw down the sound?Cause with a single exhaust from the center without big turning in the tube and a full race pipe,damn its going to be hell
What size should i buy from apexi for my 3" tube?Also is there a possibility for this part to stuck?And is this part going to throw my performance???
That's actually a pretty good idea, I wonder how it would fair....
But if you look at the photo of the item, it looks to go in between the midpipe and exhaust. That's the spot where the exhaust is connected by 2 bolts. The midpipe-header spot is connected by 3.... Also, if I was you, you should go call Mazsport and tell them about your idea, go tell Scott. He should know the size you need.
GrRx8MaZdA
04-24-2008, 03:24 PM
The problem is if this get stuck or if i forget that i have it completely closed and push the car and with the turbo i ll have a problem..
well for a turbo'ed car you might have a problem. If it gets stuck you could manually pull the line, whats the price? And if you could actually change your cars sound I doubt you'll ever forget that you can do that....
TeamRX8
04-24-2008, 03:47 PM
Had one on my original 3" exhaust
it will kill the sound, but the backpressure kills any type of acceleration
had to almost keep it closed all the way to be effective
GrRx8MaZdA
If only i make a race pipe with a resonator but i hate permanent resonators..I want it angry.. :) Anyhow.thanks for the opinion
GrRx8MaZdA
04-24-2008, 03:48 PM
Hey Team..Did you sale it?Do you have turbo on??Any problems in its fuction???What size did you have on??
staticlag
04-24-2008, 03:52 PM
OH! nevermind, I thought this was something else.
Well dude, honestly I wouldn't worry about it, a catless car with a turbo on it is as quiet as a stock car even if it has a new catback.
This is what I thought that it was: http://www.jegs.com/p/Doug%27s+Headers/759640/10002/-1/11529
GrRx8MaZdA
04-24-2008, 03:59 PM
Man i have a single exhaust from the center..You cant imagine how loud it was with a cat and even with the stock cat on...Without a cat daaaaaamn i cant imagine..I hope the turbo quiets it down a bit..
TeamRX8
04-24-2008, 04:00 PM
http://www.rx8club.com/showpost.php?p=1345200&postcount=51
I ended up getting rid of it and just added a dual pipe split with mufflers on the rear
The turbo will help, but catless it will still be loud, I'd recommend splitting the 3" into dual 2.25" pipes at the rear for turbo (2" for NA) with a pair of these instead
http://www.pegasusautoracing.com/productselection.asp?Product=1840
if yu want to stick with a single 3" then order the 3" ID x 6.25" OD model of this with the stainless scrubble packing option:
http://www.coastfab.com/ultralights.html
