View Full Version : No air pump?
KKMmaniac
12-24-2002, 12:26 AM
So, I haven't seen a reference to it in print yet, but all the pictures I've seen so far of the Renesis are missing one very critical item - The air pump! Could it be, the Renesis is a clean enough running engine that this parasitic, wheezing, needs one extra belt to drive it, space taking up, hydrocarbon-reducing and sometimes thermal-reactor cooling, heavy lump of metal that has been present on all rotaries (I think) that have been imported to the United States; been eliminated? (It was by me on my first RX-7, which caused me major grief later on)
Also, I know this has been discussed, but has it been stated in print, what octane fuel the engine will require? I know NA rotaries happily burn lower octane gas, but it has been noted a couple times anyway, the Renesis has higher compression.
Hercules
12-24-2002, 12:33 AM
Also, I know this has been discussed, but has it been stated in print, what octane fuel the engine will require? I know NA rotaries happily burn lower octane gas, but it has been noted a couple times anyway, the Renesis has higher compression. I'll probably just wind up putting 93 octane in it; it's now become quite a habit and I don't forsee anything BAD happening by putting a cleaner gasoline in the tank.
Quick_lude
12-24-2002, 12:42 AM
Do you mean Air conditioning? :confused:
KKMmaniac
12-24-2002, 12:50 AM
Air conditioning is a given these days, but if I could, I'd probably not get A/C if I could have a sun roof!
I meant the vane (I think) type pump bolted to the engine to provide low pressure air to the intake manifold and catylists to help burn the gasses left over from incomplete combustion.
Hercules
12-24-2002, 01:07 AM
I meant the vane (I think) type pump bolted to the engine to provide low pressure air to the intake manifold and catylists to help burn the gasses left over from incomplete combustion. Gets too hot in the summer not to have A/C :(
wakeech
12-24-2002, 02:33 AM
omg, Herc and Qlude, i hope you guys are just fakin' the naivete... the air pump that was the staple technology in early pollution control, the one responsible for the 150 hp corvette (or whatever it was...)???
no, this sucker won't have an airpump, and i don't know of many cars that have any (if one does at all anymore...)... the port layout on this engine allows the HC rich gas, which stays near the trailing tip of the rotor, to be blocked from entering the expiration port in the first place, to be recycled and (eventually) properly combusted. this measure in itself is responsible for the huge reduction in HC emissions...
also, Buger (a while ago) posted a link to an article on Mazda's latest 3-way cat, which was some big leap over "conventional" 3-ways, with some sort of core material eureka factor... it's late, and i can't remember details...
so, this above technology MIGHT be making a difference, but don't forget that the cats of today are leaps and bounds above the cats of only ten years ago...
Aesculapius
12-24-2002, 12:16 PM
I thought that higher octane gas actually was a worse polluter.
Quick_lude
12-24-2002, 12:30 PM
Haha.. I'm not faking.. I've never heard or seen an "air pump".. When/where was it used last?
wakeech
12-24-2002, 12:54 PM
when were they used last??? holy smoke man, what a question...
well, i dunno that much about it, but i do know that there were air-pumps in the FC's, and i'm pretty sure those were gone by the FD (which was saddled with a choker of an exhaust system, which was also CAST IRON!! :p)
wakeech
12-24-2002, 01:08 PM
in the wrong application, a higher octane gas may in fact pollute more than the octane specified for the vehicle... like in my GLORIOUS toyota 1.6L, i know that octane shouldn't exceed 89, so i fill it with 87 ;)
if i were to put in 93, i'm sure that combustion wouldn't be nearly as complete, as the flashpoint of the fuel is so much higher, and the compression of the engine is mid 9's and the air/gasoline mixture wouldn't reach tempuratures necessary for complete combustion in the cooler spots of the combustion chamber... the timing is wrong, the fuel curves are wrong, etc, etc... it's not made for it.
now, i dunno about the yankee regs, but i know that Canadian gas is about as clean as a mud-puddle, rife with sulfur, which contributes greatly to acid rain (and can quickly render catalytic converters, AND emissions equipment useless)... maybe this higher octane fuel is of a higher standard and contains less sulfur??
Spining Ncnratr
12-24-2002, 06:34 PM
Olds Intriege 02 has an Air pump I kid you not look for your self
3.5 L V6 to pass emissions:eek:
wakeech
12-24-2002, 11:20 PM
heh, like i said, i don't know all that much about it...
but, <<snicker snicker>> American cars, eh?? :rolleyes:
the worst imports in existance... :p
heh heh heh!! i'm such a Canadian snob... ;)
KKMmaniac
12-25-2002, 12:07 AM
I thought I had seen an air pump in a picture showing the FD engine, but I'm not sure. I don't know what other cars had or have them, my 1969 Datsun 510 did.
Anyway, I'm glad they aren't necessary on the rotary any more!
randyc
12-25-2002, 12:32 AM
Octane is all about rate of burn, not cleanliness. And yes, some engines will be cleaner with lower octane, as it burns faster.
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=5;t=000144
http://www.faqs.org/faqs/autos/gasoline-faq/part3/
wakeech
12-25-2002, 11:44 AM
oh, okay. i dunno, just thought maybe the two would correlate... eh, doesn't really matter :)
thanks for the info bro.
Aesculapius
12-26-2002, 10:27 AM
Thanks for the info!
WantedTwo
06-25-2008, 05:50 PM
Dude, I think we can answer this one now and tell all the noobs in this thread to SEARCH!!!
NotAPreppie
06-25-2008, 06:30 PM
Were you TRYING to dig up a 5.5 year old thread?
WantedTwo
06-25-2008, 06:38 PM
No, I was searching to find some info on the air pump and found these two threads. The other one is 6.5 :D:
MazdaManiac
06-25-2008, 06:52 PM
The only thing better than a threadsurrection is a threadsurrection of a misinformed thread.
champi0n
06-25-2008, 10:44 PM
is this air pump the same thing as an EGR? (exhaust gas recirculation) where it takes exhaust and dumps it into the intake?
pgrothe
06-25-2008, 11:13 PM
KKManiac was probably refering to this...
http://www.mazsport.net/store/index.php?l=product_detail&p=154
There is an air pump in the RX8, it's on the passenger side, right under the strut bar.
swoope
06-26-2008, 12:33 AM
this wins the tread revival contest.. wow. 5.5 yrs..
master.
beers :beer:
delhi
06-26-2008, 12:35 AM
I believe the 2007+ 2.5l turbo Subarus now employ air pumps and eliminated one catalytic converter in the uppipe.
