omg ...warning light..help help
Old Apr 23, 2008 | 12:31 PM
luv4eternity's Avatar
Low is a lifestyle
i was driving my 8 down to utah ....the first 3 hours were ok ...after that , the oil warning light came on ....i was like...oh **** .....i thought my oil was low and when i check it , it was considerably low...so i bought a 5w20 shell oil to top it up ...
as i was driving for the rest of the 9 hours , it kept coming on ....i was able to make it go away by stepping the clutch and wait till the rev goes down to 1000 rpm ...it disappears ...then i put it back in gear ...
i realized if i drive 80 or below , it wont come on ...but if i drive more than 80 for 30 seconds , it WILL APPEAR !!! [PICS ATTACHED!]
anyone know whats going on ? i dont want my 8 to break down when i drive back on friday ~please please please
Old Apr 23, 2008 | 01:29 PM
Jethro Tull's Avatar
Living In The Past
Are you in Utah now? Provo/Orem area?
I'd take it to Legacy Mazda, on University Parkway Blvd.
Is it under warranty?
Otherwise, check for leaks. See if the filter is screwed-on tight. If you can't find a leak, it means it probably went out the tailpipe. Maybe an OMP malfunction??
Is it really low when it comes on after you drive over 80?
Old Apr 23, 2008 | 04:00 PM
MikeTyson8MyKids's Avatar
What did the dipstick read?
A) Before you added oil.
B) Right after you added oil, and how much did you add?
C) What does it read right now with the intermittent light?
With that we might be able to help you out more. Could be as simple as a sensor malfunction. If i were to guess, I think you are probably still low. Could be wrong though.
Old Apr 23, 2008 | 05:07 PM
Low is a lifestyle
before add = 2/10
after add half bottle and drive 200 miles till I have to get gas again = 1/2
pour everything else in and drove another 400+ miles = no idea yet ... Will check after this and post as edit
Old Apr 23, 2008 | 05:11 PM
Low is a lifestyle
I'm now at Utah ... 2 miles from byu ...I recently install k&n typhoon v2 two weeks ago .... Would that have cause it ? If I take it to the dealership, would they void my warranty becoz I changed the intake ? I have extended warranty
Old Apr 23, 2008 | 09:39 PM
kobe24mvp's Avatar
that sucks man.. i would think it would void the warranty, but im not too sure.. where exactly are you by byu? i live like a mile from there
Old Apr 24, 2008 | 02:47 AM
Low is a lifestyle
DAYS inn....i think the road's name is freedom or something ...
Old Apr 24, 2008 | 03:21 AM
if it is an 04 and the oil pan was not updated it will do that usually in the 70 to 76 mph range. you just have to put more oil in it..
you need to understand that the low to top of the oil fill on the dip stick is 1.75 qts..
so if it was real low and you put a qt in, well you barely put a dent in it..
also there is a tsb for the issue..
Old Apr 24, 2008 | 03:36 AM
Low is a lifestyle
wait wait ... so u think its still low ? i put like the whole bottle in but it still stays on should i go get another bottle ?
Old Apr 24, 2008 | 04:25 AM
if it got low enough to put on the light. yep.. and did you think to look at the dipstick??
Old Apr 24, 2008 | 01:11 PM
Low is a lifestyle
I just check it .... It was a little shy off the middle ... Pour another bottle in .... Would it be enough ? Do I need to keep an extra just in case ?
Old Apr 24, 2008 | 01:15 PM
Silver06's Avatar
Zoom Zoom....
Yes, keep extra oil in the car.
Yes, check the oil every second fill-up. (every fill-up if driving track-days or sustained high revs)
Yes, keep the oil level between 3/4 and just under full on the 04 dipstick...
Old Apr 27, 2008 | 12:51 AM
Low is a lifestyle
i check my dip stick and it says its full ....drove down to las vegas and IT STILL CAME ON ...but less frequent ...when i check it , it is still full ....could it still be the oil pan problem ?
Old May 1, 2008 | 05:50 PM
Low is a lifestyle
i went to mazda and got it check ...they say i need to upgrade my oil pan and change my oil pressure sensor thingi ....and my extended warranty doesnt cover it ...is there any problems if i DONT change this things or is there anywhere i can change it for a good deal ?
Old May 1, 2008 | 06:09 PM
Nothing , its just that ur light will annoy the crap outa you.
Just remember to check ur oil more often thats all.
Old May 2, 2008 | 03:38 AM
Low is a lifestyle
ok ..thanks so much
Old May 2, 2008 | 03:45 AM
ok ..thanks so much
04, how many miles on the car? sorry if i missed it.
Old May 2, 2008 | 07:03 AM
invasion08's Avatar
Check this out Mazda has a TSB for this problem http://www.finishlineperformance.com...13-04-1341.pdf
Old May 2, 2008 | 11:32 AM
Low is a lifestyle
before i left for UTAH ..it was around 37,+++ ....not its 39,997
Old May 2, 2008 | 11:36 AM
Low is a lifestyle
thanks for the info....great help for me to understand ...i feel relief now ...
i'll probably not do it till my next oil change ...and since its not harming my car , i'll see if i NEED to do it in future ...THANKS for the feed backs ^^
Old May 2, 2008 | 11:57 AM
Huey52's Avatar
Registered Zoom Zoomer
It won't do any harm as long as you don't become complacent to your ill-mannered warning light and continue to check your oil level often.
For your sanity, and ease of potential resale, you should get it done however.
Safe trip.
Old May 2, 2008 | 12:08 PM
Nubo's Avatar
Lubricious
Man, that is BS. This is a known defective part with a TSB. It should have been replaced 4 years ago. Mazda owe you a new oil pan, under warranty. It is not a wear item!
Old May 2, 2008 | 02:50 PM
car is still under original warranty.
Old May 2, 2008 | 09:06 PM
Low is a lifestyle
no ...ended on end of march 2008 ...SAD !!
Old May 2, 2008 | 09:11 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^+1............get it done when you can and check that oil often, but don't overfill either.
