m3pkrobert
04-22-2008, 11:08 PM
the left bulb is not working nomore and need to replace it but i couldnt get it out
i dono how is the easy way to do it, cause i read the manual and it said is hard to do it, and its better to take it to the dealer, i dono if someone can give a hand with this so i dont hav to go all the way to the dealer and do it myself thanks
spokenstone
04-22-2008, 11:46 PM
http://www.rx8club.com/showthread.php?t=36067&highlight=DIY+foglight
This should help you.
nycgps
04-23-2008, 07:49 AM
IS not hard, You have to take like what, 10 or 15 of the 10mm bolt out to take off the front bumper. then u just locate the light, *twist* and it will come out.
416to212
04-23-2008, 08:21 AM
Uhhh... Please don't listen to NYCGPS advice....
There is no need to remove the front bumper.
The DYI thread will be most helpful. However, I've found that there is no need to completely remove the spash guard. Just undo enough to bend back the splash guard and you'll be fine.
m3pkrobert
04-23-2008, 09:43 AM
NICE! FOR SURE WILL HELP :)
nycgps
04-23-2008, 11:02 AM
Well you dont HAVE to, you can reach it from under tray, or the cover like the DIY saids.
but I found that when u take the bumper off, u might as well clean some unexpected things trapped around the area.
DUH
m3pkrobert
04-23-2008, 10:24 PM
DUH
ill do it tomorrow, i was checking today and is true is not that hard thanks for the advise
nycgps
04-23-2008, 11:32 PM
if you really take your bumper off, you might as well spray some engine cleaner in the A/C condenser and water all the dirt and shit out.
You probably gonna find some dead animal around the area. lol
Happened to me. :)
